Need help
14 REPLIES 14
Gadta89
Message 1 of 15
Message 1 of 15
Need help
Hello,
please medion help me with this. I realy need bios update to fix microcode.Cant find help with medion support no 1 help me.
14 REPLIES 14
Igor28
Message 2 of 15
Message 2 of 15
Hello @Gadta89 ,
Could you please give us the MSN and serial number SN of your device?
Kind regards
Gadta89
Message 3 of 15
Message 3 of 15
MSN:10025150
Serial number:01100251500100042
B660H7W0X.212 11.09.2024 Bios version
Igor28
Message 4 of 15
Message 4 of 15
Hi @Gadta89,
Thank you for information.
I have requested a BIOS update. I will send you the updates when I receive a response.
Gadta89
Message 5 of 15
Message 5 of 15
Thank you! Can’t wait
Igor28
Message 6 of 15
Message 6 of 15
Hi @Gadta89 ,
The BIOS Version 212 you have is the latest available version.
Kind regards
Gadta89
Message 7 of 15
Message 7 of 15
Are you planing to change microcode with new update or need to change  motherboard with normal brand.Every company did only im person who waiting
Igor28
Message 8 of 15
Message 8 of 15
Hi @Gadta89 ,
To assist you further, we need to confirm the revisions on the mainboard currently installed in your PC.
Please open the side panel of the unit and locate the white label towards the back.
You should have a code that shows on the label, with 1.0 or 1.
If it is 1.0, please see below a link for the BIOS update below :
https://www.gigabyte.com/Motherboard/Z790-AORUS-ELITE-AX-rev-10/support#support-dl-driver
If it is 1, please see below a link for the BIOS update below :
https://www.gigabyte.com/Motherboard/Z790-AORUS-ELITE-AX-rev-1x/support#support-dl-driver
Kind regards
Gadta89
Message 9 of 15
Message 9 of 15
This is my board. Is not gigabyte. Board is ECS elite group and is 1.0 v. This gigabyte bios cannot install on etc motherboard
https://www.ecs.com.tw/en/Product/Motherboard/B660H7-M20/specification
RAZZ
Message 10 of 15
Message 10 of 15
hi @Gadta89 @Igor28
I have opened an investigation with Medion to see if they are able to assist and get the correct fix for your CPU via a BIOS update for your board, as this comes from the board manufacturer ESC unfortunately there may be a slight delay,
as soon as I get an update we I be in  contact,
Thanks
14 REPLIES 14
