Need help
14 REPLIES 14
Gadta89
Message 1 of 15
Message 1 of 15
Need help
Hello,
please medion help me with this. I realy need bios update to fix microcode.Cant find help with medion support no 1 help me.
14 REPLIES 14
Gadta89
Message 11 of 15
Message 11 of 15
Big thank you to you!!!I hope to find fix I’m looking for  last 4 months.
RAZZ
Message 12 of 15
Message 12 of 15
hi @Gadta89 @Igor28 ,
As this was affected with this 13th/14th gen stability topic, this was solved with Bios 2.12 as mentioned in this Community FAQ
Currently 2.12 is the latest one which was available and successfully evaluated.
I hope this helps and solves your issue
thanks
tokareev_
Message 13 of 15
Message 13 of 15
Hey !
Im actually in the same sh*t than you bro… I recently bought an i7-13700F but it seems that my motherboard B660H7-M20 isn’t for 14th… I tried by multiple ways to Fix it, but as you said, we can’t update it by the BIOS… 😭 I tried with the Windows method, by the « cmd » but it still not working cause the security BIOS is actived and EVEN THIS we can’t disable from the BIOS.
Did you find a way for you ? You are maybe my only hope and way to fix it because nobody is talking about this problem…
(sorry for my bad english)
Gadta89
Message 14 of 15
Message 14 of 15
Hi mate,
https://community.medion.com/t5/FAQs/How-do-I-optimize-the-stability-of-my-desktop-PC-with-an-Intel/...
download . and follow instructions
ECS B660H7-M20 (MSN 20070914, 20071254) Version 2.12
tokareev_
Message 15 of 15
Message 15 of 15
Hello,
Unfortunately, i did everything right as it say by the « cmd » (run at admin),  this happened, but nothing changed… Well im losing hope.
14 REPLIES 14
