power supply for MEDION Notebook E6247
14 ANTWOORDEN 14
bublik
Bericht 1 van 15
10.611 Weergaven
Bericht 1 van 15
10.611 Weergaven
Hi everyone,
bought a MEDION Notebook E6247 on Amazon but the Notebook is missing power supply. So far I found out this needs a 65W 3,42A 19V charger but I'm having troubles finding the dimensions of the power supply's pin that goes into the Notebook.
Can someone please help with that info or even better send a link to a compatible power supply I can buy on Amazon or somewhere else?
Would really appreciate your help on this matter.
Thank you!
14 ANTWOORDEN 14
Bericht 11 van 15
3.432 Weergaven
Bericht 11 van 15
3.432 Weergaven
@bublik
Sorry to hear that.
May be you can go into an electronic supplier shop and test different plugs. The one which fits tells you the exact measurements, and you could connect it to the wires of the Power Supply you had bought.
But I wonder there came no matching plug with the power supply.?  Is the 3.5 mm plug too thick? Or the hole for the pin too small?
bublik
Bericht 12 van 15
3.417 Weergaven
Bericht 12 van 15
3.417 Weergaven
@daddle The hole in the notebook is slightly larger than the 3.5 outer plug. And feels like the 1.35 in the plug is too small for the pin into the hole.
I think I'm sending this back to Amazon, this is getting too complicated and Medion never got back to me.
Thanks for your help and patience!!!
bublik
Bericht 13 van 15
3.411 Weergaven
Bericht 13 van 15
3.411 Weergaven
@daddle @Fishtown
Did last try at a local Chinese store and of course they had the proper plug which is 5.5*2.5, could be useful to someone else in the future looking at this thread
Bericht 14 van 15
3.406 Weergaven
Bericht 14 van 15
3.406 Weergaven
hello @bublik
Nice that you found a suitable power supply.
but that also says that the information stored in the database is not correct.
hello @Andi  (moderator) can you please verify that. thanks
E6247 / MSN30031867
PSUP Chicony A18-065N3A P5 3 Pin 65W / MSN40073024
DC plug dimension is 3.5*1.35*11mm in = + out = -
however, according to @bublik  information it is 5.5*2.5
bye Fishtown
Bericht 15 van 15
3.392 Weergaven
Bericht 15 van 15
3.392 Weergaven
Hello everyone.
That is correct.
The connector dimensions are 5.5mm x 2.5mm x 11mm.
@bublik   schrieb:
I found this one for exemple, but nor sure the charger's pin has compatible dimensions, 2.5/5.5, would that work? Thank you
https://www.amazon.it/LEICKE-Alimentatore-Medion-Notebook-KSAFI1900342T1M2/dp/B0028PUWA8/ref=sr_1_2?...
Yes, that works.
@daddle  schrieb:
Or you trust us, or leave it. We can not give you a link to the Medion Database, but we can read!  😉
But you seemingly not 🙂
Your choice of words is absolutely inappropriate and impertinent. Stop insulting other users in this way.
That is correct. Thank you for the information.
This was an error in our database. This has already been corrected. Thank you very much for the hint.
Greetings - Andi
14 ANTWOORDEN 14
