S2218 notebook Date not retained
2 REPLIES 2
Goldflipflop
Message 1 of 3
Message 1 of 3
For my S2218 notebook the Date/TIme is not retained after power off.     Does this machine have a replaceable CMOS battery?    If not, any suggestions for solving this?
1 ACCEPTED SOLUTION
Goldflipflop
Message 3 of 3
Message 3 of 3
Thank you to Fishtown for the pointer to another contribution.
My S2218 had been without power for about 6 months. I think the main battery was completely empty.  After the machine had received some charge it was able to run. It started with a default date. After a short run with network connection it received network time.  The S2218 realtime clock was then correct.  After a power down and restart the Date and TIme started correctly without any network update.   Problem gone away!
I think this means the Realtime clock is supported by the Main battery possibly indirectly via a rechargeable motherboard battery.
2 REPLIES 2
Message 2 of 3
Message 2 of 3
Hi @Goldflipflop and welcome
According to this German contribution, she has a CMOS battery
https://community.medion.com/t5/Notebook-Netbook/MEDION-AKOYA-S2218-MD-99595-wie-%C3%B6ffnen-um-CMOS...
bye Fishtown
Goldflipflop
Message 3 of 3
Message 3 of 3
2 REPLIES 2
