14.09.2023 20:30
14.09.2023 20:30
Hi so i bought this laptop in 2018 and it has worked great until about november last year (2022) when the cpu started overheating which basically i solved by buying a new fan and thats it. After maybe 4 months it started overheating again and then i decided to change the thermal paste maybe that would have worked but today it started overheating again.
Can anyone offer me any solutions ?
Thanks in advance.
14.09.2023 23:37
14.09.2023 23:37
Hi @Gum
I assume you cleaned the complete airways, and also removed the dust in between the cooling fins. And also from the PSU and the cooling ventilators of the graphic card?
And you have applied enough thermal paste?
Did you upgrade the Proc ?
Bye, daddle
15.09.2023 00:57
15.09.2023 00:57
Hi @daddle ,
Yes i cleaned everything numerous times. The thermal paste i applied is the same i usually apply and all my other computers or the ones i worked on, work perfectly fine, its just this one I'm having trouble with. And for your last question the proccesor it's the same it came with I have not change any parts except for the fan.
Thanks for answering I'm open to any other comments.
Bye Guille.
15.09.2023 11:25 - edited 15.09.2023 11:27
16.09.2023 08:50
16.09.2023 08:50
Hello @Gum and welcome
How do you know that the CPU is overheating?
What is the temperature and where was it displayed?
can you check the measured temperatures with a thermostat or infrared measuring device?
does the fan turn at the moment of overheating?
You control the fans via the control center 2, have you reinstalled them to rule out a software malfunction. What happens if you deactivate this and leave the control to the computer itself? does it overheat too?
Bye Fishtown
