Akoya P6667 touchscreen and 360 hinge replacement?
1 REPLY 1
CitywideMars50
Message 1 of 2
Message 1 of 2
Could I replace the Medion Akoya P6667's 15.6" 1366x768 LCD with a touchscreen and flattening hinge so it's possible to use it as a sort of ipad/notebook? What about replacing with a higher res screen? I thought it was pretty straightforward but not sure if the motherboard supports it.
1 REPLY 1
RAZZ
Message 2 of 2
Message 2 of 2
Hi @CitywideMars50 ,
Regarding changing your screen we @ medion can only advise on replacing original parts not upgrades, Looking at your unit you would have to change the whole units casing for a flattening hinge to be attached and this would not be able to fit in the internal components correctly. For a touch screen to be installed you may need further hardware components & software added again which may not fit or be compatible.
we would advise against this or at least check with a professional to see what you would need.
thanks
Upgrades and modifications to your PC/laptop should only be carried out by a qualified specialists. If you do not have the necessary qualifications, have the work
carried out by a qualified service technician
1 REPLY 1
