Original BIOS Akoya P6687 - MD61006
30 RÉPONSES 30
kuro2
Message 1 sur 31
14 400 Visites
Message 1 sur 31
14 400 Visites
Hello.
Can you send me original bios installer for Akoya P6687 - MD61006, to restore my computer?
Many thanks.
30 RÉPONSES 30
heywire2
Message 21 sur 31
3 602 Visites
Message 21 sur 31
3 602 Visites
Try this bios: https://we.tl/t-itRsMfTaBf
javigom
Message 22 sur 31
3 597 Visites
Message 22 sur 31
3 597 Visites
@heywire2
Same message: "This BIOS is not for your Notebook PC."
Message 23 sur 31
3 591 Visites
Message 23 sur 31
3 591 Visites
@javigom
Is your battery inbetween 50 and 95 % and active charging? You Powersupply is connected to the wall outlet? did you start as admin?
javigom
Message 24 sur 31
3 588 Visites
Message 24 sur 31
3 588 Visites
@daddle
Yes to all.
Message 25 sur 31
3 527 Visites
Message 25 sur 31
3 527 Visites
Hi @javigom ,
I can abolutely confess, that @heywire2 posted the right Bios for the MEDION P6687 laptop.
Do you have the option to find out,which current Bios is on your machine?
Cheers
javigom
Message 26 sur 31
3 520 Visites
Message 26 sur 31
3 520 Visites
Hi, @Major_ToM
Thanks for reply, I have the 209 BIOS version. I have take a screenshot so you can see what appears to me when trying to install version 208.
javigom
Message 27 sur 31
3 516 Visites
Message 27 sur 31
3 516 Visites
@Major_ToMHere is the screenshot. Thanks.
Update: I have uploaded it to Drive (https://drive.google.com/drive/folders/1c96dOTHzQTzqIZgtZAlIB4H2dWPpjasb?usp=sharing)
Message 28 sur 31
3 509 Visites
Message 28 sur 31
3 509 Visites
Thanks @javigom ,
okay.. thanks, mate. Seeing your pictures I suppose what might have happened.
You need to install a Bios of the PGT F15KxR (2.08) barebone, but somehow accidentally got the Bios of the PGT F15KR (which currently is 2.09)
We can try a switchback and maybe this helps.  Would you please execute this package ?
+++Information+++
Please remind, that for any errors, caused by the execution of this update, we don´ t accept any responsibility for damage or lost of data.executing the update.
Cheers
javigom
Message 29 sur 31
3 498 Visites
Message 29 sur 31
3 498 Visites
Hi @Major_ToM,
I have decided to execute the file that you have sent me under my own responsibility, because the laptop was still not working and the warranty was expired, and ... IT HAS WORKED! I thank you very much for all your time and your dedication, because the Medion support did not give me any solution and I really considered it lost. I hope this post helps more people who have experienced the same thing as me.
Eternally grateful ❤️, Javi.
Message 30 sur 31
3 488 Visites
Message 30 sur 31
3 488 Visites
HI @javigom ,
following this thread it seemed to me as a "rough ride" for you to get to the solution.
In the end we got this together, very appreciated 🙂
Finally it would be nice, to mark my answer as solution by clicking the approriate "Solution button" on the right underneath of the solving answer.
This helps other Commmunity users with similar issues to solve their problem faster, cause your initiated TOP is then highlighted as "already solved"
Cheers
30 RÉPONSES 30
