on 17.07.2018 12:33
on 17.07.2018 12:33
Hello.
Can you send me original bios installer for Akoya P6687 - MD61006, to restore my computer?
Many thanks.
on 19.02.2021 10:17
on 19.02.2021 10:34
on 19.02.2021 11:07
on 19.02.2021 11:21
on 26.02.2021 06:29
on 26.02.2021 06:29
Hi @javigom ,
I can abolutely confess, that @heywire2 posted the right Bios for the MEDION P6687 laptop.
Do you have the option to find out,which current Bios is on your machine?
Cheers
on 26.02.2021 07:45
on 26.02.2021 07:45
Hi, @Major_ToM
Thanks for reply, I have the 209 BIOS version. I have take a screenshot so you can see what appears to me when trying to install version 208.
26.02.2021 07:47 - edited 26.02.2021 07:50
@Major_ToMHere is the screenshot. Thanks.
Update: I have uploaded it to Drive (https://drive.google.com/drive/folders/1c96dOTHzQTzqIZgtZAlIB4H2dWPpjasb?usp=sharing)
on 26.02.2021 08:11
on 26.02.2021 08:11
Thanks @javigom ,
okay.. thanks, mate. Seeing your pictures I suppose what might have happened.
You need to install a Bios of the PGT F15KxR (2.08) barebone, but somehow accidentally got the Bios of the PGT F15KR (which currently is 2.09)
We can try a switchback and maybe this helps. Would you please execute this package ?
+++Information+++
Please remind, that for any errors, caused by the execution of this update, we don´ t accept any responsibility for damage or lost of data.executing the update.
Cheers
on 26.02.2021 11:42
on 26.02.2021 11:42
Hi @Major_ToM,
I have decided to execute the file that you have sent me under my own responsibility, because the laptop was still not working and the warranty was expired, and ... IT HAS WORKED! I thank you very much for all your time and your dedication, because the Medion support did not give me any solution and I really considered it lost. I hope this post helps more people who have experienced the same thing as me.
Eternally grateful ❤️, Javi.
26.02.2021 12:21 - edited 26.02.2021 12:22
HI @javigom ,
following this thread it seemed to me as a "rough ride" for you to get to the solution.
In the end we got this together, very appreciated 🙂
Finally it would be nice, to mark my answer as solution by clicking the approriate "Solution button" on the right underneath of the solving answer.
This helps other Commmunity users with similar issues to solve their problem faster, cause your initiated TOP is then highlighted as "already solved"
Cheers
