Original BIOS Akoya P6687 - MD61006
30 ANTWOORDEN 30
kuro2
Bericht 1 van 31
15.677 Weergaven
Bericht 1 van 31
15.677 Weergaven
Hello.
Can you send me original bios installer for Akoya P6687 - MD61006, to restore my computer?
Many thanks.
30 ANTWOORDEN 30
heywire2
Bericht 21 van 31
3.980 Weergaven
Bericht 21 van 31
3.980 Weergaven
Try this bios: https://we.tl/t-itRsMfTaBf
javigom
Bericht 22 van 31
3.975 Weergaven
Bericht 22 van 31
3.975 Weergaven
@heywire2
Same message: "This BIOS is not for your Notebook PC."
Bericht 23 van 31
3.969 Weergaven
Bericht 23 van 31
3.969 Weergaven
@javigom
Is your battery inbetween 50 and 95 % and active charging? You Powersupply is connected to the wall outlet? did you start as admin?
javigom
Bericht 24 van 31
3.966 Weergaven
Bericht 24 van 31
3.966 Weergaven
@daddle
Yes to all.
Bericht 25 van 31
3.905 Weergaven
Bericht 25 van 31
3.905 Weergaven
Hi @javigom ,
I can abolutely confess, that @heywire2 posted the right Bios for the MEDION P6687 laptop.
Do you have the option to find out,which current Bios is on your machine?
Cheers
javigom
Bericht 26 van 31
3.898 Weergaven
Bericht 26 van 31
3.898 Weergaven
Hi, @Major_ToM
Thanks for reply, I have the 209 BIOS version. I have take a screenshot so you can see what appears to me when trying to install version 208.
javigom
Bericht 27 van 31
3.894 Weergaven
Bericht 27 van 31
3.894 Weergaven
@Major_ToMHere is the screenshot. Thanks.
Update: I have uploaded it to Drive (https://drive.google.com/drive/folders/1c96dOTHzQTzqIZgtZAlIB4H2dWPpjasb?usp=sharing)
Bericht 28 van 31
3.887 Weergaven
Bericht 28 van 31
3.887 Weergaven
Thanks @javigom ,
okay.. thanks, mate. Seeing your pictures I suppose what might have happened.
You need to install a Bios of the PGT F15KxR (2.08) barebone, but somehow accidentally got the Bios of the PGT F15KR (which currently is 2.09)
We can try a switchback and maybe this helps.  Would you please execute this package ?
+++Information+++
Please remind, that for any errors, caused by the execution of this update, we don´ t accept any responsibility for damage or lost of data.executing the update.
Cheers
javigom
Bericht 29 van 31
3.876 Weergaven
Bericht 29 van 31
3.876 Weergaven
Hi @Major_ToM,
I have decided to execute the file that you have sent me under my own responsibility, because the laptop was still not working and the warranty was expired, and ... IT HAS WORKED! I thank you very much for all your time and your dedication, because the Medion support did not give me any solution and I really considered it lost. I hope this post helps more people who have experienced the same thing as me.
Eternally grateful ❤️, Javi.
Bericht 30 van 31
3.866 Weergaven
Bericht 30 van 31
3.866 Weergaven
HI @javigom ,
following this thread it seemed to me as a "rough ride" for you to get to the solution.
In the end we got this together, very appreciated 🙂
Finally it would be nice, to mark my answer as solution by clicking the approriate "Solution button" on the right underneath of the solving answer.
This helps other Commmunity users with similar issues to solve their problem faster, cause your initiated TOP is then highlighted as "already solved"
Cheers
30 ANTWOORDEN 30
