Medion P7618 BIOS big problem
60 REPLIES 60
busa
Message 1 of 61
Message 1 of 61
hi, I have a problem with my Medion Akoya P7618 (MD98580), I downloaded and flashed the last bios from medion website (http://www.medion.com/de/service/_lightbox/treiber_details.php?did=10611), and now the wifi and external graphics card (GT540M) don't work anymore, how I can fix the problem or where I can download the orginal BIOS for the laptop?
Thanks.
Tags (3)
60 REPLIES 60
aBash
Message 51 of 61
Message 51 of 61
Hello, i have the same problem. Need the BIOS 009 File too. Can anyone send me this File?
Message 52 of 61
Message 52 of 61
@aBash
Read on Page 5 Busas post from 25.12.15, 12:37.
There ia a functioning link for a functioning Bios V 009.
Regards, daddle
Message 53 of 61
Message 53 of 61
@aBash Did you get the bios-file?
An answer or remark would be fine!
pervoisto4nik
Message 54 of 61
Message 54 of 61
Hello i need old BIOS version was like 009 Medion P7618 BIOS. can help
Message 55 of 61
Message 55 of 61
Moin @pervoisto4nik and welcome
have you see the Post 52 from @daddle  ?
https://drive.google.com/open?id=0B70osO6OK2ueZndaWUJQT1FUTDA
Please also read the entire article
pervoisto4nik
Message 56 of 61
Message 56 of 61
writes =(
ROM file ROMID is not compatible with existing BIOS ROMID.
pervoisto4nik
Message 57 of 61
Message 57 of 61
I changed the firmware to 009 BIOS
the graphics started to work! wifi does not work =(
Message 58 of 61
Message 58 of 61
Moin @pervoisto4nik
sorry, you wanted 009, you get 009.
There is no prehistory of you and now wifi does not work.
what should we recommend to you now?
Check network adapter drivers in device manager
Message 59 of 61
Message 59 of 61
@pervoisto4nik  schrieb:
writes =(
@pervoisto4nik
You have to flash in Admin mode.
Check the drivers in device manager; and check if you switched the wifi accidentally off by FN 7?
regards, daddle
Message 60 of 61
Message 60 of 61
@Frog
@Frog  schrieb:
Even if I could manage to get the old BIOS version, you would not be able to install it. The flash procedure will find a newer version installed and cancel the process.
To be honest, I really don't think that any of your notebooks issues are caused by the newer (and optimized) BIOS.
Um mal mit diesem alten Mythos aufzuräumen, in diesem Fall (Und in vielen anderen auch ) funktioniert das sehr wohl, und hat es ja nachweislich auch.
Es hängt sicher davon ab, ob das Bios-Update komplett ist.
Und es war in diesem Fall  das Bios V.100B dass die Fehler in Win 10 produzierte, die mit der V 009 nicht auftreten.
60 REPLIES 60
