MIM 2210 Notebook PC - RAM upgrade
11 REPLIES 11
jim232
Message 1 of 12
Message 1 of 12
I have a MIM 2210 Notebook PC with 1GB RAM.
According to Mr Memory I can upgrade to 2GB.
Does anyone know where the RAM slots are located and how to get into the PC? There is no information at all on this in the User Guide and Medion support offered no help.
Thanks.
11 REPLIES 11
Bodgekin
Message 2 of 12
Message 2 of 12
Hi @jim232
I'm sorry, but I've not been able to find any info on what this notebook can take either, I guess it is a little to old, considering it was delivered with Windows Vista?
To replace the memory, usually you should be able to remove a panel on the bottom side to acces the modules to replace them, though on some notebooks you can acces 1 slot through the bottom, and the second one by removing the keyboard.
Perhaps you can add some pictures from the bottom or the inside so we can have a look?
Kind regards,
Bart
jim232
Message 3 of 12
Message 3 of 12
Bart,
Many thanks for taking the time to look at this. I've only just had another reply from Medion Support, this time much more helpful. They reckon I can get access to both slots under the bottom battery compartment as you suggest. I'll have a go & if any problems will post some photos.
You're right, it is an old notebook but I'm hoping to breathe a little bit more life into it.
All the best,
Jim
jim232
Message 4 of 12
Message 4 of 12
I opened up the back panel but can't see any RAM. There are quite a few screws around the outside of the laptop bottom. Don't know whether to try them or go for the keyboard. I've seen a YouTube video on removing a keyboard - I guess it would be a similar procedure for mine...
Tags (4)
Bodgekin
Message 5 of 12
Message 5 of 12
Hi @jim232
It is a bit hard to see on the picture, but I think the memory slots are to the left of the harddrive (the metal frame with the big circular hole in it). The black stuff there looks like some black plastic foil I have seen before in notebooks, I think this is some sort of insulation. Try to carefully lift it up a bit and see if the modules are below it (if it is indeed a bit of foil).
Kind regards,
Bart
jim232
Message 6 of 12
Message 6 of 12
Bart,
Thanks for the further advice - much appreciated.
I wondered what could be under there. On cursory inspection it didn't look designed for removal but if you've seen similar before then that's very good to know. Next time I get my hands on the machine I'll try to lift it - carefully as you say and will post the outcome.
All the best,
Jim
Luke
Community Manager
Message 7 of 12
Message 7 of 12
Hello @jim232 and @Bodgekin,
I`ve just checked our (old) databases and all I could find out is that this unit
has been sold in 2007, max. RAM upgrade is 2 GB using
2x  1GB DDR2 400MHz 200 PIN SO-DIMM PC2-3200S
If my memory serves me right, both RAM slots should be located below
the keyboard, but I need some additional information for a precise
advice. What I need is at least the MD-number  of this notebook
("MD 96175" or such) and it`s MSN  number.
Cheers,
Luke
jim232
Message 8 of 12
Message 8 of 12
Luke,
Thank you for looking into this.
On the site I quoted on my original post they are selling
1GB DDR2 PC2-5300 667MHz 200-pin SODIMM for this device
So I guess I could try & find a match for original RAM or buy 2 of the 667MHz modules above.
On the back plate of machine is S/N: KNB721001174
- hopefully that is same as MSN you asked for & will uniquely identify the device. No sign of an MD number - perhaps these were introduced after 2007?
I attach photo of back plate.
Please let me know if you need any other identifiers.
Thanks again,
Jim
Luke
Community Manager
Message 9 of 12
Message 9 of 12
Hi again @jim232,
I finally found a MIM 2210 datasheet in a prehistoric part of our Intranet!   Smiley Wink
However, we still don`t know where the RAM slots are located ( I still assume it`s underneath
the keyboard), but once you`ve found them I can now assure that you may replace the 2x 512 MB
with 2x 1 GB RAMs. There shouldn`t be a problem using your faster 667 MHz RAMs, they are
just faster than your mainboard and will be bored most of the time.
Here`s the datasheet, incl. a (german) MSN & MD-number. Text is also in German,
but should be understandable:
Hope this helps,
Luke
jim232
Message 10 of 12
Message 10 of 12
Luke,
Excellent - helps a lot. Nice to see it has an official datasheet! When I get another chance to look at the machine I'll update here.
Many thanks,
Jim
11 REPLIES 11
