MEDION AKOYA P 7624 MD 98970
9 RÉPONSES 9
mamuka
Message 1 sur 10
13 721 Visites
Message 1 sur 10
13 721 Visites
hello, my laptops bios setup is locked by password, and i can not switch wifi radio in bios setup, please help me. i have medion support disks, but they dont helped me. when i inserting "application and support disk" and pressing f11 in recovery manu writs that "there is not factory image" ,  how can i reset bios password? please help me
 i have reinstall windows 7 home premium from this disk and install all drivers. but results are same20190322_151836-min.jpg20190322_151904-min.jpg20190322_152918-min.jpg20190322_152934-min-min.jpg20190322_153006-min.jpg20190322_153039-min.jpg20190328_224449-min.jpg20190328_224957-min.jpg20190328_225012-min.jpg20190328_225025-min.jpg20190328_225519-min.jpg
9 RÉPONSES 9
SlamRam
Retired
Message 2 sur 10
13 713 Visites
Message 2 sur 10
13 713 Visites
Hey @mamuka, welcome to the community.
Unfortunately there's no easy fix for this. Rather than playing around with the motherboard/CMOS to try and clear the password, I would suggest contacting Medion support as parts may need to be replaced.
Cheers!
SlamRam
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
mamuka
Message 3 sur 10
13 710 Visites
Message 3 sur 10
13 710 Visites
i was plug out the cmoss battery for 15-20 minutes but result not changed.
Message 4 sur 10
13 694 Visites
Message 4 sur 10
13 694 Visites
hey @mamuka
https://recoverit.wondershare.com/de/computer-recovery/bios-password-cracker.html
I hope it work
https://www.datenrettung-fakten.de/Nachrichten/bios-passwort-zuruecksetzen-mit-dem-pc-cmos-cleaner.h...
https://www.netzwelt.de/download/14148-cmospwd.html
Bye Fishtown
Raymond
Scientist
Message 5 sur 10
13 683 Visites
Message 5 sur 10
13 683 Visites
Bonjour @mamuka
I would turn off the power overnight. 20 minutes are too little. Alku away, power supply away and CMOS battery away. over night. That can make you wonder. Again a try! Smiley clignant de l'œil
Gruß Raymond
Raymond
Scientist
Message 6 sur 10
13 673 Visites
Message 6 sur 10
13 673 Visites
Hello @mamuka
But alright, sometimes I want to be a naive optimist. Better tested a possibility than to stamp it as "meaningless" from the outset. But hope dies last?
But that's the way @SlamRam  writes. The password is probably no longer stored in the CMOS, but in an EPROM. That must be exchanged?
(Everything was better before) Smiley clignant de l'œil
Gruß Raymond
mamuka
Message 7 sur 10
13 660 Visites
Message 7 sur 10
13 660 Visites
hello
thanks for attantion, but unfortunetelly this solutions did not helped 😞 i try bypass pasword with cmospwd, pc cmoscleaner, and ubcd...
Luke
Community Manager
Message 8 sur 10
13 657 Visites
Message 8 sur 10
13 657 Visites
Hello @mamuka,
As far as I can see there are only 2 possible solutions left to
resolve your problem:
1.
Send your notebook to our service.
2.
After checking your IP I know you are living far away from any of our european support services. I would therefore suggest to install a cheap Wifi-USB adapter to get online quick & easy.
Cheers,
Luke
mamuka
Message 9 sur 10
13 655 Visites
Message 9 sur 10
13 655 Visites
then tried, eject cmoss battery all ower night and day, still nothing... 😞
there is one way, if i desolder bios ic and backup bios rom with "ch341a" - programer from china
then erase bios flash from ic and reinstall it agane, will it be setted to the default values?
i flashed bios asus motherboard and it worked 100%.  but i'm not sure will it works for this medion laptop, i don't want to demage my laptop.
RS13
Master NL
Message 10 sur 10
13 633 Visites
Message 10 sur 10
13 633 Visites
Hi @mamuka
As far as I know, the BIOS has no option to permanently turn off the Wifi. It can be set to either Off or Last state, but this only determines the state of the Wifi module on start-up, you should still be able to turn the Wifi on and off using the FN - F7 key combination (If this does not work, you might have to reinstall the Launchmanager).
Kind regards,
Paul
9 RÉPONSES 9
