Keyboard problem S4403
48 RÉPONSES 48
AndrewP
Message 1 sur 49
50 474 Visites
Message 1 sur 49
50 474 Visites
I have a problem with my keyboard and hope someone can help.
Recently I had an update to my VPN fail. The installer automatically rolled back the installation, but this did not complete correctly and, after rebooting twice I noticed various problems with my notebook. I have succeeded in resetting the icon spacing on the task bar and the line spacing in File browser, but I have a problem with the keyboard occasionally repeating characters as I type. Usually it only repeats one character but occasionally it will repeat the last two characters so that for example "the" comes out as "ththe". I know my typing is not perfect but this is much more frequent that before and I never repeated two characters like this.
I have tried changing the repeat key delay setting in Windows but it does ntoto help. [I left ntoto in as an example that just happened, I mistyped not as nto (a common mistake for me😁) but it came out as ntoto].
Does anyone have any ideas?
Thanks!
S4403 - MD 61325, Windows 10 Home v20H2, build 19042.804, Windows Feature Experience Pack 120.2212.551.0
48 RÉPONSES 48
AndrewP
Message 31 sur 49
8 655 Visites
Message 31 sur 49
8 655 Visites
@daddle @PathMan
I am on version 20H2, build 19042.804, Windows Feature Experience Pack 120.2212.551.0
The HID Event Filter is still visible in my version.
PathMan
Message 32 sur 49
8 650 Visites
Message 32 sur 49
8 650 Visites
@AndrewP - i have the 2.2.1.384 driver installed and unfortunately, the "Roll back" option is greyed out, so I can't do that!
I have downloaded the earlier driver but aam having no luck gettting it unzipped and insttalled?
I  have installed 7Zip and can unzip it, but do I need to unzip to a specific loccation to get it tto replace the later verrsion?
You can see from the above what the issue is doing to my typing!
PathMan
Message 33 sur 49
8 650 Visites
Message 33 sur 49
8 650 Visites
@daddle - thank's for your response. I am on Build 19042.867
When I right click the extracted .inf file, what option should I select? Install? It doesn't aappear to do anything?
Message 34 sur 49
8 649 Visites
Message 34 sur 49
8 649 Visites
@PathMan
No, just decompress it to any folder. But not only opening by 7zip, you have to do a physical unpack, and have the three files in an extra folder.
If you do an inf-install, theres no reaction to be seen, as far as I remember. Even if it doesn't work.
But if you still have the entry Hid Event Filter, and it shows V.  ...384,  go back to V.  .... 383
---> https://www.catalog.update.microsoft.com/Search.aspx?q=intel+hid+event+filter
You hav to go two or three pages forward to find Version ..383
Do a Uninstall, and mark "Delete Driver software" as well, then do a driver update and show the path to the folder with the decompressed  " hideventfilter.inf "
Yes, your Build 19042.867 is the same as on my desktop, but my entry 'IntelHid Event Filter' isn't there anymore.
cheers, daddle
PathMan
Message 35 sur 49
8 638 Visites
Message 35 sur 49
8 638 Visites
Thank you @daddle !
That worked like a charm!
The driver is now the earlier version and my repeating keyboard errors appear to be fixed!
Hurray, I owe you a pint!
AndrewP
Message 36 sur 49
8 632 Visites
Message 36 sur 49
8 632 Visites
@PathMan  Did you also have problems with the icon spacing on the task bar and the line spacing in File Exporer?
I wonder how many more people have had this problem.
AndrewP
Message 37 sur 49
8 628 Visites
Message 37 sur 49
8 628 Visites
@daddle  my windows has just done an update to:
Edition Windows 10 Home
Version 20H2
Installed on ‎2020-‎10-‎25
OS build 19042.867
Experience Windows Feature Experience Pack 120.2212.551.0
The Intel(R) HID Event Filter entry is still visible.
Message 38 sur 49
8 623 Visites
Message 38 sur 49
8 623 Visites
@AndrewP
Thanks for the info:
OK, everything the same, but your Windows version was installed  ‎2020-‎10-‎25 , mine on 2021-02-01
All the same, except the date
Version 20H2
Installed on ‎2021-02-01
OS build 19042.867
PathMan
Message 39 sur 49
8 619 Visites
Message 39 sur 49
8 619 Visites
@AndrewP
I didn't notice any problem with the icon spacing and/or line spacing in File Explorer?
AndrewP
Message 40 sur 49
8 615 Visites
Message 40 sur 49
8 615 Visites
@daddle  interesting that the versions of Windows are the same but the Device Manager looks fairly different (ignoring language). I guess most of the differences are because mine is a touch-screen laptop.
But what is definitely different is the number of entries in the HID group:
Why do I have so many copies of some drivers? Is there any benefit in removing duplicates? And if so, how do I deceide which to keep?
Thanks!
48 RÉPONSES 48
