14.02.2022 20:22
12.04.2022 09:44
12.04.2022 09:44
Hi @Wip ,
sorry for the late reply, but the MEDION AKOYA E15307 has the option to take another m.2 SDD with the capacity of 1000 GB max.
Cheers
15.02.2022 16:33
15.02.2022 16:33
Hi, to give you a correct answer you should tell us rhe MSN number of your PC.
Your Notebook has a bottom slot called a slot for flash memory expansion module (M.2 2280 SATA).
But most probably this slot already contains your boot ssd. But I am not completely sure. This usually is regular with the Emdoor barebones.
cheers, dadddle
12.04.2022 09:44
12.04.2022 09:44
Hi @Wip ,
Cheers
