on 28.03.2022 12:10
on 28.03.2022 12:10
Is there a way to switch the function of the Fn keys (for instance immediately lowering screen brightness when pressing F5 and using the normal F5 function by pressing Fn + F5). For my previous (lenovo) laptop this was (quite easily) possible and now I'm very much used to it, but here I can't seem to find it. Hope someone is able to help! (and hope this is the correct discussion board for this question)
on 29.03.2022 15:47
on 29.03.2022 15:47
Hi Dan1999,
Welcome to the community!
Do you have the MSN of your E16401?
Thanks
Mats749
on 13.04.2022 09:20
on 13.04.2022 09:20
HI @Dan1999 ,
just wanted to ask, if you found a solution in the meantime,or are yoiu still in need of assistance?
In this cas pls leave a short note by mentioning me with the @ sign before the user which should be notyfied by your asnswer.
Cheers
