How do I set the start delay on my MD 19100 Robot Vacuum Cleaner?
The Robot Vacuum Cleaner must be in standby mode (the blue LED lights up). Then simply go through the following steps:
(30) Start time
button on the remote control until the time flashes on the display.yellow button (25)
.If you want to set a different start delay, proceed again as described above. If you want to delete the start delay, switch the device off and on again at the bottom.
⚠️Note⚠️: Removing the battery from the remote control does not cancel the start delay.
⚠️Important⚠️: The remote control must have visual contact with the robot, there must be no obstacles in between.
This FAQ supplements chapter 7.1 Setting the start delay of the international manual (DE, FR, NL, ES, IT DK, SE + NO).
ChangeLog:
Article in other languages:
Review Date: 2025-05-07
