FAQs about the MEDION MD 12090 slush ice maker
  • General questions
    • What can I prepare with the slush ice maker?
    • With this appliance, you can make slushies, cocktails, milkshakes, wine slush, beer slush and many other refreshing drinks.
    • What is the capacity of the device?
    • The slush ice maker has a capacity of 2.6 litres, so you can prepare several portions at once.
    • What slush modes are available?
    • The device offers five different modes to achieve the perfect consistency:
      • Slush Soft: For soft, fruity slushies
      • Slush Hard: For a firmer, icy consistency
      • Milkshake: For creamy milkshakes
      • Wine Slush: Chilled wine enjoyment
      • Cocktail Slush: Perfect for alcoholic mixed drinks
    • Is the slush ice maker easy to use?
    • The high-quality spout handle allows you to easily portion the slush ice with just one hand movement.
    • Is there a minimum and maximum fill level?
    • The minimum fill level is 500 ml. The maximum filling capacity is 1900 ml of liquid.
  • Functionality & Technology
    • Why do I have to hold the device upright for 2 hours before using it for the first time?
    • Place the appliance on the worktop for at least 2 hours before use. This allows the refrigerant to settle in the condenser for optimum and safe use.
    • Why can the screw conveyor freeze or become blocked?
    • If the sugar content is not sufficiently high or there is too little alcohol, the screw conveyor can freeze to the evaporator and become blocked.
    • What can I do if the screw conveyor is frozen solid or blocked?
    • Switch off the appliance and wait until the drink has thawed. Adjust the mixing ratio according to the instructions (sugar content higher than 6% or alcohol content from 2% to 16%).
    • Is there a way to adjust the consistency?
    • Yes, the device has a consistency control that allows you to adjust the slush texture to your liking (from soft and liquid to firm and icy).
    • Is the device safe for children?
    • Yes, the Slush Ice Maker MD 12090 has a child safety lock so that it can only be used by adults.
    • Can I turn off the acoustic signals?
    • The device has a button that allows you to activate or deactivate the acoustic signals as desired.
  • Cleaning & maintenance
    • Is the device easy to clean?
    • Thanks to the integrated self-cleaning function, cleaning is particularly easy. All you have to do is fill it with water and activate the self-cleaning mode.
    • Can I take the device apart to clean it?
    • Some parts, such as the container and lid, can be removed for easier cleaning.
  • Usage & Tips
    • How can I ensure that my recipes turn out well and do not freeze solid?
    • It must be ensured that the mixture always contains a sugar content of 6% or higher (this corresponds to 114 g of sugar per 1.9 litres) or an alcohol content of 2% to 16%.
    • Can I use liquids other than water?
    • You can use fruit juices, lemonade, soft drinks, dairy products and even alcoholic beverages to create different slush variations.
    • How long does it take for the slush ice to be ready?
    • The preparation time depends on the desired consistency, but is usually between 30 and 45 minutes.
    • Can I put ice cubes in the appliance?
    • No, the device is designed for liquids that it processes into slush independently.
    • Can I pour hot liquids into the slush maker?
    • No, the device is only designed for cold or chilled liquids. Hot liquids can damage the material.
  • Technical data & warranty
    • What is the power output of the device?
    • Our appliance has a powerful 200-watt motor, ensuring fast and efficient preparation.
    • What should I do if the device does not work?
    • Please check:
      • Whether the device is connected correctly.
      • Whether the lid and all parts are correctly assembled.
      • Whether the child safety lock is activated.
      If the problem persists, please contact our customer service.
Version history
Last update:
‎05.09.2025 07:37
Updated by:
Labels (2)
Contributors
