Thousands of event log Warnings from source WHEA-Logger Event ID 17
18 REPLIES 18
seanbirkhead
Message 1 of 19
Message 1 of 19
Hi,
I have literally thousands of these warnings occurring several times per minute.
Can anyone direct me towards a solution?
Laptop is a MEDION ERAZER P15805 (MD 61593) UK
This is what is in the event log :
A corrected hardware error has occurred.
Component: PCI Express Root Port
Error Source: Advanced Error Reporting (PCI Express)
Primary Bus:Device:Function: 0x0:0x1D:0x0
Secondary Bus:Device:Function: 0x0:0x0:0x0
Primary Device Name:PCI\VEN_8086&DEV_A336&SUBSYS_85501558&REV_F0
Secondary Device Name:
- <System>
  <Provider Name="Microsoft-Windows-WHEA-Logger" Guid="{c26c4f3c-3f66-4e99-8f8a-39405cfed220}" />
  <EventID>17</EventID>
  <Version>1</Version>
  <Level>3</Level>
  <Task>0</Task>
  <Opcode>0</Opcode>
  <Keywords>0x8000000000000000</Keywords>
  <TimeCreated SystemTime="2020-12-09T22:48:55.9590600Z" />
  <EventRecordID>661862</EventRecordID>
  <Correlation ActivityID="{7e1e7ee5-ec71-44d6-b42d-da86c315a368}" />
  <Execution ProcessID="6200" ThreadID="8024" />
  <Channel>System</Channel>
  <Computer>ERAZER</Computer>
  <Security UserID="S-1-5-19" />
  </System>
- <EventData>
  <Data Name="ErrorSource">4</Data>
  <Data Name="FRUId">{00000000-0000-0000-0000-000000000000}</Data>
  <Data Name="FRUText" />
  <Data Name="ValidBits">0xdf</Data>
  <Data Name="PortType">4</Data>
  <Data Name="Version">0x101</Data>
  <Data Name="Command">0x10</Data>
  <Data Name="Status">0x407</Data>
  <Data Name="Bus">0x0</Data>
  <Data Name="Device">0x1d</Data>
  <Data Name="Function">0x0</Data>
  <Data Name="Segment">0x0</Data>
  <Data Name="SecondaryBus">0x0</Data>
  <Data Name="SecondaryDevice">0x0</Data>
  <Data Name="SecondaryFunction">0x0</Data>
  <Data Name="VendorID">0x8086</Data>
  <Data Name="DeviceID">0xa336</Data>
  <Data Name="ClassCode">0x30400</Data>
  <Data Name="DeviceSerialNumber">0x0</Data>
  <Data Name="BridgeControl">0x0</Data>
  <Data Name="BridgeStatus">0x0</Data>
  <Data Name="UncorrectableErrorStatus">0x0</Data>
  <Data Name="CorrectableErrorStatus">0x1000</Data>
  <Data Name="HeaderLog">00000000000000000000000000000000</Data>
  <Data Name="PrimaryDeviceName">PCI\VEN_8086&DEV_A336&SUBSYS_85501558&REV_F0</Data>
  <Data Name="SecondaryDeviceName" />
  </EventData>
  </Event>
18 REPLIES 18
sweetpoison
Message 11 of 19
Message 11 of 19
Try to install a driver from Realtek
Also, coming back to what i said before: remove the adaptor from device manager, restart windows, install driver, leave windows to run few min then restart it.
seanbirkhead
Message 12 of 19
Message 12 of 19
I installed the latest driver  from the Realtek site which was newer than the one that that Windows update had installed.
It did not solve the problem unfortunately even after installing / rebooting etc. in the sequence you suggested.
I rolled back to the Microsoft driver again  and the problem goes away again.
In fact I get faster throughput over LAN when using the Microsoft Driver than when using the Realtek driver.
I'm probably not going to keep chasing this any more as the Microsoft driver seems stable , error free and fast so I have created a group poilcy rule to prevent any future updates to the LAN card driver.
This should cause Windows update to fail when it tries to update the driver and then I can just hide that update when and if that happens.
seanbirkhead
Message 13 of 19
Message 13 of 19
Since rolling back to the Microsoft driver I have had 0 errors for the last 3 days.
ludwig1970
Message 14 of 19
Message 14 of 19
Still haven't gotten the problem back?
I have a Medion laptop with the same problem and I am at my wits end.
Regards
Ludwig
seanbirkhead
Message 15 of 19
Message 15 of 19
Hi @ludwig1970 ,
I've never had the problem again since reverting to the Microsoft Driver and sticking with it.
Windows has never tried to update the driver again either because of the group policy rule I created so I couldn't say if there is a newer Realtek driver that solves the issue.
Regards,
Sean
ludwig1970
Message 16 of 19
Message 16 of 19
Thank you very much for responding. regards Ludwig
keiji
Message 17 of 19
Message 17 of 19
In the device manager, a wide variety of items appear, but the specifics of "in device manager I uninstalled every peripheral device (except for my c: drive) and at the same time chose the option to uninstall the driver for the device." Please tell me how to do it.
sweetpoison
Message 18 of 19
Message 18 of 19
Welcome to the forum @keiji
In device manage doubleclick on the specific driver you want to alter and in "driver" tab you find the buttons to do that.
sample
A word of advice, when you decide to "work" on device manager you need to know 3 things: what, how and why you want to edit.
As a general rule is to know how to repair in case something goes wrong.
Cheers
seanbirkhead
Message 19 of 19
Message 19 of 19
Just adding some more detailed steps here as I have seen other posts related to similar problems.
My issue was the Realtek LAN card and more specifically the Realtek driver for that card.
To expand on my own solution:
I had to do the following steps.
1. Take the laptop offline i.e. disconnect any wifi connection or LAN cable. This is important as Windows update immediately tries to re-install the manufacturer drivers from Windows online update during later steps.
2. From device manager , I uninstalled the network card AND ticked the box to delete the existing driver. This is also important otherwise Windows will just use the same driver again when it re-installs the network card later if you don't chose the option to delete the existing driver.
3. Reboot the laptop. It is important that the laptop stays disconnected from the internet during and after reboot so if using wifi make sure it doesn't automatically re-connect. If in doubt it might be just a good idea to switch off the internet router to be sure.
4. After reboot Windows should have re-installed the device and used the Microsoft in-built drivers.
If this solves the problem and there are no more WHEA-logger entries in event viewer  then the following needs to be done before bringing the laptop back online.
5. Create a group policy to prevent future automatic driver updates for the problematic device. Group policy editing is only available through a GUI on Win 10 Pro but there is a workaround that still allows it to be done through registry entries on Win 10 Home. There are instructions for doing this (including the Win 10 Home workaround here : https://www.tenforums.com/tutorials/146562-prevent-windows-update-updating-specific-device-driver.ht... )
6. Once the group policy is in place or the registry edited you can then bring the laptop back online and the driver should not update again in future.
18 REPLIES 18
