My BIOS isn’t saving my keyboard lighting settings.
13 REPLIES 13
Thomas92Kr
Message 1 of 14
Message 1 of 14
Every time I reboot my laptop, my keyboard lighting settings are reset and I have to turn them off again in the BIOS. Is there a way to fix this?
Medion Erazer Beast X25 (MD62182)
2 ACCEPTED SOLUTIONS
Message 4 of 14
Message 4 of 14
Hi @Thomas92Kr
You can find the control center by entering your MSN number on the Medion service page:
https://www.medion.com/gb/service/product-detail/30033045
bye Fishtown
Mastermind
Message 8 of 14
Message 8 of 14
Hi @Thomas92Kr ,
the unzipped UWP App owns a .cmd commandline file, which is an executable file format, and I think it´s quite logical that you have no App to start unless you install thge App, isn´t it?
Anyhow, could you also please check the Microsoft store, cause for recent model series the ERAZER Control Center App is also rolled out via the store.
Feedbacuj very appreciated
13 REPLIES 13
Message 2 of 14
Message 2 of 14
Hello @Thomas92Kr  and welcome
briefly asked:
How do you exit the BIOS? just with esc = exit
or with F4 = save and exit?
Can't you also control/adjust the lighting in the control center?
bye Fishtown
GM7ZG7P: https://fccid.io/2AKHFAX200NG/User-Manual/AX200NGW-UserMan-5174928.pdf
Thomas92Kr
Message 3 of 14
Message 3 of 14
Hello @Fishtown thank you for your response. I always save and exit. And I’ve also done a clean Windows install after purchasing my laptop, so I don’t think I have an control center. I also can’t find anything about a control center in the manual.
Message 4 of 14
Message 4 of 14
Hi @Thomas92Kr
bye Fishtown
Thomas92Kr
Message 5 of 14
Message 5 of 14
Hi @Fishtown I've downloaded and installed the Control Center software however, I don't see an app I can launch. Untitled.png
I do see a RGBKeyboard reg file but I don't know what that will do when I register it.
Can you help me with this?
Mastermind
Message 6 of 14
Message 6 of 14
Hi @Thomas92Kr ,
I unfortunately have no such unit in hand, but having the Control Center/Gaming Center from both downloads from the MEDION service page correctly
you should have a Control Center/Gaming Center tray icon in your task bar.
Cheers
Thomas92Kr
Message 7 of 14
Message 7 of 14
Hi @Major_ToM I do not have a tray icon in my task bar.
I've only managed to install the 'Control Center Service Software MEDION ERAZER Beast X25'.
The 'Control Center UWP App MEDION ERAZER Beast X20/X25' does not have an executable that I can run.
Kind regards,
Thomas
Mastermind
Message 8 of 14
Message 8 of 14
Hi @Thomas92Kr ,
Thomas92Kr
Message 9 of 14
Message 9 of 14
@Major_ToM Thank you it worked!!
Mastermind
Message 10 of 14
Message 10 of 14
Awesome, @Thomas92Kr ! 🙂
13 REPLIES 13
