Does medion erazer guardiamn x10-md 61799 use thermal pads or thermal putty on gpu vram?
1 REPLY 1
xavidzn
Message 1 of 2
Message 1 of 2
Hello,
I own a Medion Erazer Guardian X10 MD 61799 and I'm planning to replace the thermal paste on the CPU and GPU. Before opening the heatsink, I want to confirm whether I need to purchase thermal putty for the GPU’s VRAM, or if this laptop uses thermal pads instead. Has anyone disassembled their laptop for this purpose and can provide insights?
Thanks in advance!
1 REPLY 1
Mastermind
Message 2 of 2
Message 2 of 2
Hi @xavidzn ,
you might check this disussion and thementioned PTM 7950 Thermal pad, which one user mentioned.
Cheers
1 REPLY 1
