Medion Erazer P6681 Fan constantly on full
3 ANTWOORDEN 3
Whewell
Bericht 1 van 4
4.975 Weergaven
Bericht 1 van 4
4.975 Weergaven
Hi all,
I have had my Medion Erazer for about a year now and my fan has just started to run at high RPMs even though the processor and GPU are both cool. I have replaced the thermal paste in hopes that it would solve this issue but that didn’t work. The only other problems I can think of may be the Fan itself or something is wrong with the bios.
Could anyone suggest anything?
Thanks in advance!
3 ANTWOORDEN 3
SlamRam
Retired
Bericht 2 van 4
4.949 Weergaven
Bericht 2 van 4
4.949 Weergaven
Hello @Whewell, welcome to the community!
If you haven't done so yet you can update the BIOS using the link below and see if this resolves the issue you're experiencing. Should this not help I would recommend you contact Medion support using the this link so they can assist you further.
Bios update
Have a great day!
Cheers!
SlamRam
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
Whewell
Bericht 3 van 4
4.944 Weergaven
Bericht 3 van 4
4.944 Weergaven
Hi @SlamRam,
Thank you for your reply!
I have updated the bios to the latest on their website.
I did contact them before but they never replied. I’ll try to contact them again just to be sure.
Thank you once again.
Bericht 4 van 4
4.922 Weergaven
Bericht 4 van 4
4.922 Weergaven
Hi @Whewell,
nice that this one obviously is solved now.
If you receive a helping answer, it would be nice to mark you question as solved by clicking the approriate "Solution button" on the right underneath of the solving answer.
This helps other Commmunity users with similar issues to solve their problem faster, cause your initiated TOP is then marked as "already solved"
Thank you
3 ANTWOORDEN 3
