on 07.02.2019 18:43
on 07.02.2019 18:43
Hi all,
I have had my Medion Erazer for about a year now and my fan has just started to run at high RPMs even though the processor and GPU are both cool. I have replaced the thermal paste in hopes that it would solve this issue but that didn’t work. The only other problems I can think of may be the Fan itself or something is wrong with the bios.
Could anyone suggest anything?
Thanks in advance!
on 19.02.2019 13:22
on 19.02.2019 13:22
Hello @Whewell, welcome to the community!
If you haven't done so yet you can update the BIOS using the link below and see if this resolves the issue you're experiencing. Should this not help I would recommend you contact Medion support using the this link so they can assist you further.
Have a great day!
on 19.02.2019 13:29
on 21.02.2019 08:53
on 21.02.2019 08:53
Hi @Whewell,
nice that this one obviously is solved now.
If you receive a helping answer, it would be nice to mark you question as solved by clicking the approriate "Solution button" on the right underneath of the solving answer.
This helps other Commmunity users with similar issues to solve their problem faster, cause your initiated TOP is then marked as "already solved"
Thank you
Subject | Author | Posted | |
12.02.2024 20:56 | |||
27.04.2024 09:47 | |||
28.01.2025 17:41 | |||
28.02.2021 00:26 |
