How to enter bios menu ?? HELP PLEASE
17 ANTWORTEN 17
kaanozkans
Nachricht 1 von 18
35.993 Aufrufe
Nachricht 1 von 18
35.993 Aufrufe
Hi guys i have an medion erazer 57001 gaming desktop,my question is how can i enter the bios menu for formatting my pc.i cant find it please help me
MSN number : 10023368
MD : 34664
17 ANTWORTEN 17
kaanozkans
Nachricht 11 von 18
6.165 Aufrufe
Nachricht 11 von 18
6.165 Aufrufe
Are you crying baby boy :(((
Nachricht 12 von 18
6.163 Aufrufe
Nachricht 12 von 18
6.163 Aufrufe
@kaanozkans
No. definitely not. But you are impertinent. Stop this, or you will get into trouble yourself,
And teach yourself to make use of a more decent language,
Luke
Community Manager
Nachricht 13 von 18
6.147 Aufrufe
Nachricht 13 von 18
6.147 Aufrufe
Good Morning!
@kaanozkans:
Please stay on topic, and a feedback if our hints did help would be great.
@daddle:
Danke, mein Verständnis der englischen Sprache war bislang durchaus ausreichend. Es geht hier nicht um Wörter wie "f*ck", sondern um deine Attitüde.
@All:
This thread will be closed as soon as the problem has been solved.
Nachricht 14 von 18
6.105 Aufrufe
Nachricht 14 von 18
6.105 Aufrufe
Hi @kaanozkans ,
do you still need any assistance in your case, or can we close this one?
Greets
balanadi
Nachricht 15 von 18
5.230 Aufrufe
Nachricht 15 von 18
5.230 Aufrufe
I Would like to know how can i download the bios update for
MEDION AKOYA E6246 (MD63200)
MSN=30025987.
I was doing windows 10 update and after the bios update i forced stopped the laptop before finishing the update and now i need help .
I need a way to boot from usb , with the bios image so i can use the laptop again.
PLEASE HELP
Nalle85
Nachricht 16 von 18
3.247 Aufrufe
Nachricht 16 von 18
3.247 Aufrufe
Hi
I use to hold down "del and som F1,F2,F3" at the same time turn on the computer
and you will enter bios, some times you can tap this keys when the screen is going on.
I hope this will help you 🙂
Nachricht 17 von 18
3.217 Aufrufe
Nachricht 17 von 18
3.217 Aufrufe
Hi @Nalle85 and thanks for your reply.
In the most cases you get access to the Bios section by repeatedly hitting the "F2" or "Del" button (kind of a woodpecker would practice it😀), before the bootlogo appears
Cheers
neace_lacero
Nachricht 18 von 18
2.222 Aufrufe
Nachricht 18 von 18
2.222 Aufrufe
Hello,
I have useful information
I have laptop Medion E6247 - MD 61358
I managed to enter BIOS menu by clicking repeatedly F2 button at computer startup
Also I managed to enter Boot menu by clicking repeatedly F10 button at computer startup
Clicking repeatedly Del button doesn't seem to have any effect at all.
Pressing other major button like Esc, F1, F3, F4, F5, F6, F7, F9, F11, F12 also don't seem to have any effect
Similar setup can be in other models of Medion laptops
17 ANTWORTEN 17
