How can I find out what type of USB-C port i have?
9 REPLIES 9
PK_1
Message 1 of 10
Message 1 of 10
I have a Medion Erazer P6689 laptop, the model with the i7 CPU.
it has a USB-C port, but I can't find any info on whether it will work as video out
Anyone know where I can find out?
Thanks
9 REPLIES 9
Message 2 of 10
Message 2 of 10
Hi @PK_1
you have IO Ports:
1x USB 3.1 Type-C
2x USB 2.0
1x HDMI Out
and
1x LAN (RJ45) / 1x Audio-Kombo (Mic in & Audio out) / 1x Card-Reader: 2in1 Multikartenleser (SD-, SDHC- & SDXC)
why don't you use the HDMI port?
if you want to use the USB port connections for video you need a USB to HDMI adapter/converter
bye Fishtown
PK_1
Message 3 of 10
Message 3 of 10
hi @Fishtown thanks for the reply.
I can see in the documentation that the usb-c port is 3.1, which supports video, but in device manager in windows i can only see usb 3.0 ports.
I tried using 2 different usb-c to hdmi adapters and a usb-c to displayport adapter but nothing worked.
The reason I want to do this is that I have two external monitors that I would like to use with the laptop, so the hdmi port is already occupied.
Thanks
Paul
Mccarrod
Message 4 of 10
Message 4 of 10
Hi Paul,
Did you ever get this issue resolved? I'm having a similar issue with wanting to connect 2 monitors. I have purchased an Anker 14 in 1 hub which has 2 HD I ports and works fine from my Dell but the medion only works for usb devices, not the monitors. Any ideas?
Message 5 of 10
Message 5 of 10
Hi @Mccarrod ,
could you serve with the information, which laptop model you own?
Some of the USB-Type C ports just support data transfer, others do support PD or PD, but we need to know the 8-digit- MSN article number (3002xxxx) to sort things out.
Cheers
myshrm
Message 6 of 10
Message 6 of 10
I am having the same issue, I bought my PC because currys specifically said it supported video output usb-c.
My MSN is 10025150.
Message 7 of 10
Message 7 of 10
@myshrm
Be aware this is a thread about a Laptop.
If you want to know something about your  desktop pc. you should open another new thread with your questions.
By the way, with your given MSN Number I can not find any documentation about this PC. You said MSN is 10025150. Could it be instead  MSN 1002 5105?
-->  https://www.medion.com/de/service/product-detail/10025105
So please check the MSN, and give some additional information, eg the MD number, and the name.
Most of the PCs do not have a USB port with displayport function, because the dedicated graphic card  offers those connections. So in the new thread name your graphic card as well.
Additionally some mainboards also offer a displayport on the mainboard. But if you have a dedicated graphic card, those. are dysfunctional..
--> https://cdn.medion.com/downloads/anleitungen/flyer_20070297.pdf
Cheers, daddle
Message 8 of 10
Message 8 of 10
Hello @myshrm and welcome
Please link to the currys page where this is written.
I can't tell from the board Manuel ESC B660H7-M20 on your computer.
https://d2caf01sdkyx7e.cloudfront.net/dlfileecs/manual/mb/B660H7-M20/B660H7-M20_MANUAL_V1.0.pdf?Poli...
You also have an HDMI and three display ports thanks to the RTX4070 graphics card. isn't that enough?
bye Fishtown
myshrm
Message 9 of 10
Message 9 of 10
It does not specifically say this in the description but then you filter on video output "usb-c" this is one of the PCs that appears, I guess it is an error on their side.
I wanted to use usb-c as then I can switch easily between PC and work laptop, but I will just have to switch some extra cables around (MDHI and DP).
Message 10 of 10
Message 10 of 10
@myshrm
As I wrote, as long as you use a dedicated graphic card in your system, the graphic ports on your mainboard are without function; all video signals goes through the dedicated graphic cards video ports.
Please tell me what the expression "currys" mean? Is it a idiomatic expression, meaning advertisement ? Or ist ist a shop name? But then you would have written with a capital letter. And I don't think you do mean  the indian   mixed spices.
Bye, daddle
9 REPLIES 9
