Fans not working Correctly
52 ANTWORTEN 52
NinoR
Nachricht 1 von 53
23.976 Aufrufe
Nachricht 1 von 53
23.976 Aufrufe
I downloaded the new Control Center for my Medion Erazer x25 beast, and now the fast are not working properly anymore. When I want to set my own graph for the CPU I can barely edit it and it starts off all over the place. When I don't set my own graph the fan speeds stay at idle (31%) and dont go up even if the cpu is 95 degrees celcius. Does anyone know what I have to do?
52 ANTWORTEN 52
gtsuit
Nachricht 11 von 53
4.169 Aufrufe
Nachricht 11 von 53
4.169 Aufrufe
Reinstalling the control centre with the latest version, though the version number seems to be unchanged, does get the fans above 31% for me, but now they vary between 50 and 56% and won't go below or above.
The button doesn't appear to change modes any more and I think it's stuck on Office, though the fans are audible.
I get the pop up that the mode has changed but the fan speed doesn't and it's still inadequate. I still can't manually set any fan speeds with the control centre.
Edit - Just wiped the entire computer and reinstalled Windows. Great.
Turbo mode is officially non existent. Back to 31% fans.
Mauricee
Nachricht 12 von 53
4.045 Aufrufe
Nachricht 12 von 53
4.045 Aufrufe
Thank you for these promising solutions. I am also desperately looking for a solution for hours. Nothing works. The best, my fans hang at 30% and even the browser makes my laptop overheat.... cool.
Well, hopefully one of Medion has an idea how they can straighten out this crap.
gtsuit
Nachricht 13 von 53
4.036 Aufrufe
Nachricht 13 von 53
4.036 Aufrufe
Since it's got to be BIOS I can't think of one single thing to do. Maybe a new control center would work, but none of the existing ones I've tried do any more and it's not as if they pump them out on a regular basis.
We're dependent on Medion issuing a BIOS update that doesn't turn their machines into junk.
NinoR_
Nachricht 14 von 53
4.033 Aufrufe
Nachricht 14 von 53
4.033 Aufrufe
I'm planning on calling their support number tomorrow. Has anyone already tried that?
gtsuit
Nachricht 15 von 53
4.024 Aufrufe
Nachricht 15 von 53
4.024 Aufrufe
I've already emailed them. Maybe there's something straightforward that they can do.
Mauricee
Nachricht 16 von 53
4.013 Aufrufe
Nachricht 16 von 53
4.013 Aufrufe
no, not yet. was hoping it was a minor problem and the community already had a solution. Well. i'll call tomorrow too. the more the merrier. let's put some pressure on it. i didn't buy this laptop just for fun in the first place. i'm also pretty dependent on its performance.
Nachricht 17 von 53
3.713 Aufrufe
Nachricht 17 von 53
3.713 Aufrufe
Hi @NinoR_ @Mauricee @gtsuit ,
thanks for your feedback, did you take notice of this recent FAQ ?
This is a SW related issue, but we´re working on it.
Cheers
Mauricee
Nachricht 18 von 53
3.701 Aufrufe
Nachricht 18 von 53
3.701 Aufrufe
Hi Tom, yes, I have already tried that. Unfortunately, in the end, the missing functions were still not there.
I am glad to hear that you are trying to fix this problem.
Greetings.
NinoR_
Nachricht 19 von 53
3.688 Aufrufe
Nachricht 19 von 53
3.688 Aufrufe
@Major_ToM Yeah I have tried that two times in total and both times it didn’t cause a change
gtsuit
Nachricht 20 von 53
3.664 Aufrufe
Nachricht 20 von 53
3.664 Aufrufe
Medion service replied to my email telling me to send the machine in without acknowledging the actual problem.
Since this is clearly a clash between the BIOS update and the control centre I don't see what possible use sending it in would do. Unless they like keeping updates on the premises.
52 ANTWORTEN 52
