Erazer X30 Beast 2 X 2tb NVME drives?
6 REPLIES 6
Jellyfloat
Message 1 of 7
Message 1 of 7
Hi, if possible I'd like to fit 2 X 2tb NVME drives to my Erazer Beast X30.
Is this possible?
Can you recommend which drives to buy?
Can I go bigger than 2tb?
Is any setup required or is this a plug and play modification?
I do realise I will have to reinstall windows 11.
Thank you all for the benefit of your superior knowledge.
1 ACCEPTED SOLUTION
Message 3 of 7
Message 3 of 7
Hi @Jellyfloat ,
as Fishtown already mentioned,it is absolutely posible to integrate max 64 GB RAM and 2 NVME disks. We testet /evaluated just 1 TB modules, but as @Forsaked mentioned, he currently has two 4TB Seagate Firecudas 530 runing. Maybe he now can provide some feedback about the performance.
Cheers
6 REPLIES 6
Message 2 of 7
Message 2 of 7
Hi @Jellyfloat
looks good,
https://community.medion.com/t5/ERAZER-Gaming-NBs/Beast-X30-zus%C3%A4tzliche-SSD-einbauen/m-p/143705...
bye Fishtown
Message 3 of 7
Message 3 of 7
Hi @Jellyfloat ,
Cheers
Jellyfloat
Message 4 of 7
Message 4 of 7
Thank you very much. I will proceed!
Jellyfloat
Message 5 of 7
Message 5 of 7
I have a supplementary question: is there room in the case for both drives to be fitted with heatsinks?
Message 6 of 7
Message 6 of 7
Hi @Jellyfloat ,
looks good,as we as MEDION also use heatsinks ontop of our SSDs.The battery height seems(on the lower right of the opicture) to enable the opportunity.
Another hint: To mention a community user so that they are notified when you reply, write an @ sign in front of their name (e.g. @Major_Tom)
Otherwise apost mightonly be found accidentally 😉
Cheers
Jellyfloat
Message 7 of 7
Message 7 of 7
@Major_ToM  thank you
6 REPLIES 6
