le 11.03.2024 11:55
le 11.03.2024 11:55
Good morning everyone,
I recently bought this notebook and I noticed that if I close the computer screen when I reopen it the computer doesn't turn on.
To be precise, the keyboard lights are up and the fans spin, but the screen still black.
Could it be a bad driver?
Thank you!
le 12.03.2024 13:55
le 12.03.2024 13:55
EDIT:
(I can't find a way to delete or edit the post:)
I solved it, Windows Update had automatically downloaded an updated driver for the Intel graphics card.
I restored the original driver from the medion site and now everything works!
le 12.03.2024 13:55
le 13.03.2024 08:09
le 13.03.2024 08:09
Hi @little_pm96 ,
that´s really nice to hear! So keepon gaming and have much fun with your ERAZER Crawler E30
Cheers
le 23.03.2024 16:09
le 23.03.2024 16:09
Hi,
I have the same problem for my erazer E30 laptop. Where did you find the original driver on the medion website?
le 23.03.2024 18:19
le 23.03.2024 18:19
Hi @DBates96and welcome
On the one hand, you can usually find the drivers on the D drive if you bought it with the operating system
or enter your MSN number from the computer on the Medion service page, for example:
https://www.medion.com/gb/service/product-detail/30035526
bye Fishtown
23.03.2024 18:22 - modifié 23.03.2024 18:29
le 24.03.2024 12:39
le 24.03.2024 12:39
Hi,
I followed your steps and it worked! Thank you so much!
le 12.04.2024 12:59
le 12.04.2024 12:59
Hi, I am having the same problem with Erazer E30 Crawler and found the file on Medion site but as a novice I am not sure how to proceed. The folder I downloaded contains many files, can someone tell me which is the correct file to install.
Also, how do I know whether I need to install Intel or Nvidia graphics driver?
le 12.04.2024 14:28
le 12.04.2024 14:28
hello, if you have the same problem and you have downloaded the correct intel driver for your pc just run the .exe file as administrator:
install it and reboot your PC.
