am 25.11.2023 17:49
am 25.11.2023 17:49
Hello all. I wish to install 32gb of memory to my Erazer Beast X30 but I cannot open the case.
Can anyone tell me how to priced please,-
am 25.11.2023 20:51
am 25.11.2023 20:51
Yes, there are still plastic clips that you have to loosen. You can do this with a small plastic spatula in the gap between the lid and the base and, moving around the gap, prying the clips loose.
Success, daddle
am 25.11.2023 19:24
am 25.11.2023 19:24
Hello @Jellyfloat and welcome
barebone Uniwill Technology GM7AG8P
It just says that the base plate has 10 screws, which makes maintenance easier
bye Fishtown
am 25.11.2023 20:09
am 25.11.2023 20:09
Hi, and thank you for responding.
I removed the 10 screws, and the baseplate was very reluctant to move.
It felt as if there were other, hidden fixings holding it in place
am 25.11.2023 20:51
am 25.11.2023 20:51
Success, daddle
am 25.11.2023 20:57
31.03.2024 19:49 - bearbeitet 31.03.2024 19:49
This company has made all laptops impossible to get into, which is strange as cleaning your fans and changing the ram is part of having a computer. I have the same issue on my computer with no instructions any where. Last time I buy a medion laptop.
am 31.03.2024 20:18
am 31.03.2024 20:18
Hi @hennis , My X30 bottom cover came off quite easily when I followed the instructions given to me on this forum.
After removing the visible screws, a guitar plectrum eased the cover off.
It clicked most alarmingly, and fought me a little, but it did eventually come off, allowing me to upgrade the memory and fit an extra ssd
am 19.05.2024 14:13
am 19.05.2024 14:13
Sorry for the late reply, and I appreciate your time.
I have been a little worried to do this, as I've never been in a laptop, I always had desktop computers, so building up to doing it still.
The guitar plectrum is a good tip, so will buy one.
Thanks for the response.
am 19.05.2024 19:09
am 19.05.2024 19:09
Hello @hennis
Do you have two computers now?
In your other post you have one
P17815 / MSN 30028173, you received a service manual for this at the beginning of April and you don't need a guitar plectrum to open it.
bye Fishtown
17.02.2025 15:11 - bearbeitet 17.02.2025 15:15
This is what I have been saying to you.
Both those numbers I provided are from the same computer.
On the laptop it says its a Erazer P17815.
But the MSN is - 30028173
This should have been a brand new laptop brought not a refurbishment?
I was also told to download the manual on here for the
Clevo NH50RC / NH57RC
Why if this is not my laptop?
Now I have been told to use this manual for a Clevo - NH70RZQ
CAN YOU TELL ME ONCE AND FOR ALL WHAT THE HECK THE MAKE OF MY LAPTOP IS.
Also what is a memory card cover I am being told to remove in the dissemble.
I only have a hole for a card so how am I meant to remove this like it says?
Cheers.
