Erazer Beast X30 open case
10 REPLIES 10
Jellyfloat
Message 1 of 11
Message 1 of 11
Hello all. I wish to install 32gb of memory to my Erazer Beast X30 but I cannot open the case.
Can anyone tell me how to priced please,-
1 ACCEPTED SOLUTION
Message 4 of 11
Message 4 of 11
@Jellyfloat
Yes, there are still plastic clips that you have to loosen. You can do this with a small plastic spatula in the gap between the lid and the base and, moving around the gap, prying the clips loose.
Success, daddle
10 REPLIES 10
Message 2 of 11
Message 2 of 11
Hello @Jellyfloat  and welcome
barebone Uniwill Technology GM7AG8P
It just says that the base plate has 10 screws, which makes maintenance easier
https://www.notebookcheck.com/Premiere-fuer-den-Intel-Core-i9-12900H-Test-Uniwill-Technology-GM7AG8P...
bye Fishtown
Jellyfloat
Message 3 of 11
Message 3 of 11
Hi, and thank you for responding.
I removed the 10 screws, and the baseplate was very reluctant to move.
It felt as if there were other, hidden fixings holding it in place
Message 4 of 11
Message 4 of 11
@Jellyfloat
Success, daddle
Jellyfloat
Message 5 of 11
Message 5 of 11
Thanks for that
hennis
Message 6 of 11
Message 6 of 11
This company has made all laptops impossible to get into, which is strange as cleaning your fans and changing the ram is part of having a computer. I have the same issue on my computer with no instructions any where. Last time I buy a medion laptop.
Jellyfloat
Message 7 of 11
Message 7 of 11
Hi @hennis , My X30 bottom cover came off quite easily when I followed the instructions given to me on this forum.
After removing the visible screws, a guitar plectrum eased the cover off.
It clicked most alarmingly, and fought me a little, but it did eventually come off, allowing me to upgrade the memory and fit an extra ssd
hennis
Message 8 of 11
Message 8 of 11
Sorry for the late reply, and I appreciate your time.
I have been a little worried to do this, as I've never been in a laptop, I always had desktop computers, so building up to doing it still.
The guitar plectrum is a good tip, so will buy one.
Thanks for the response.
Message 9 of 11
Message 9 of 11
Hello @hennis
Do you have two computers now?
In your other post you have one
P17815 / MSN 30028173, you received a service manual for this at the beginning of April and you don't need a guitar plectrum to open it.
bye Fishtown
https://community.medion.com/t5/ERAZER-Gaming/How-Do-I-Open-The-Back-Of-An-Erazer-P17815-URGENT/m-p/...
hennis
Message 10 of 11
Message 10 of 11
This is what I have been saying to you.
Both those numbers I provided are from the same computer.
On the laptop it says its a Erazer P17815.
But the MSN is - 30028173
This should have been a brand new laptop brought not a refurbishment?
I was also told to download the manual on here for the
Clevo NH50RC / NH57RC
Why if this is not my laptop?
Now I have been told to use this manual for a Clevo - NH70RZQ
CAN YOU TELL ME ONCE AND FOR ALL WHAT THE HECK THE MAKE OF MY LAPTOP IS.
Also what is a memory card cover I am being told to remove in the dissemble.
I only have a hole for a card so how am I meant to remove this like it says?
Cheers.
10 REPLIES 10
