Eraser Beast X25 Bios 1.26MED11
26 REPLIES 26
Pete748
Message 1 of 27
Message 1 of 27
Hey Folks,
I've just had windows push a BIOS (1.26MED11) update to my laptop.
Does anyone have the patch notes?
Thank you
26 REPLIES 26
Mastermind
Message 2 of 27
Message 2 of 27
Hi @Pete748 and thanks for the screenshot.
As far as I can oversee it, there have "just" been some minor changes within the kernel code and an updated version of the AFU tool.
So nothing to hurry up and leave your family alone at the dinner table 😉
Cheers
Pete748
Message 3 of 27
Message 3 of 27
Thank you for the reply Tom.
What's the AFU tool?
Peter
Message 4 of 27
Message 4 of 27
@Pete748
Possibly  Ami Firmware Update  Tool
Cheers, daddle
agent-orangeCH
Message 5 of 27
Message 5 of 27
That BIOS was installed on my new X25 some days ago and since that I have audio anymore with the Realtek sound card. Even after a fresh installation of Windows! The only way I can get audio, is when I connect my bluetooth in-ears or my Logitech G935.
It seems like Audio is disabled in the BIOS but there no such feature in the BIOS that would let you do that.
Pastaknight
Message 6 of 27
Message 6 of 27
I believe you are correct. I even installed linux and audio didnt work.  + on audio control panel there is no recognised sound output device connector https://ibb.co/BTS5Kqp
Pete748
Message 7 of 27
Message 7 of 27
Morning/Afternoon,
If it helps my audio through the laptop speakers still works. I'm happy to run some tests to fault find if it helps. I'm on Windows 11
Below are my sound settings
ThaMadden
Message 8 of 27
Message 8 of 27
Same here.
If I show 'Hidden devices' in Device Manager the 'Realtek(R) Audio Codec with THX Spatial Audio' is still listed, but if you check the details it says
'Currently, this hardware device is not connected to the computer. (Code 45)'
Any progress on this? Not keen on reinstalling Windows (which does not seem to work anyway, as mentioned in  another post). But I do need the audio for (Zoom) meetings....
Note that the microphone is also not found anymore.
agent-orangeCH
Message 9 of 27
Message 9 of 27
Is there a way to downgrade the bios? I'd like to install 123ME10 and test if these problems are still there.
Unforuntately I dont see any hidden devices in the device manager under audio. Everything looks normal even the Medion selfservice check app didnt found any errors. I would be **beep**ed if I have to send after less than a week already to the repair-center....
Admin Edit:
Please use an appropriate language.
NinoR_
Message 10 of 27
Message 10 of 27
@agent-orangeCH Hey I doubt you have to send it back. The best thing to do wait for a new BIOS that actually works. They are already working on a solution.
After some work I had found the 1.19 BIOS and flashed it to that, my sound worked for a quick second and then it updated back to 1.26 automatically. After it was back to 1.26 audio died again
26 REPLIES 26
