Disassembly of MEDION Erazer X7847
2 REPLIES 2
JoshDog1
Message 1 of 3
Message 1 of 3
Hi all,
I have a HDD and RAM upgrade planned for my Erazer X7847 however I could not find any documentation or diagrams explaining how to do so. I have been directed towards the MEDION service portal from the Q&A of Argos. I was told that there was about 19 screws on the back to unscrew and then I could get at the HDD and RAM. I would like some sort of diagram/tutorial before disassembling my laptop.
Cheers,
Josh
2 REPLIES 2
DarkKnight
Message 2 of 3
Message 2 of 3
Hi @JoshDog1
The best I could find is the user manual on the Medion support site. It does show the screw layout on the base of your unit. https://www.medion.com/gb/service/_lightbox/handbuch_details.php?did=16170
If you are not sure or confident in upgrading your unit, then I would recommend taking it to an approved engineer such as a local PC repair shop.
Hope this helps
DarkKnight
natswright
Message 3 of 3
Message 3 of 3
Hiya, i'd be interested to know how you got on with the upgrade..... I found this article that detailes upgrading a very similar model. https://www.notebookcheck.com/Test-Medion-Erazer-X7849-MD-60292-Laptop.174545.0.html
I'm looking into buying this model, so am interested in its upgrade potential!
Thanks
Natalie 🙂
2 REPLIES 2
