Crawler E25 [ 0.314135] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPC0.EC0]
8 REPLIES 8
popus_czy_to_ty
Message 1 of 9
Message 1 of 9
BIOS Information
       Vendor: INSYDE Corp.
       Version: 1.07.05RME1
       Release Date: 05/10/2022
NHxxEx
[    0.314135] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPC0.EC0], AE_NOT_FOUND (20230628/dswload2-162)
[    0.314146] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230628/psobject-220)
Does anyone have newer version bios than this one? Linux complaining about BIOS implementation
Long time ago tried to contact insyde corp but they ignored me, and returned to medion, medion doesnt care aswell
8 REPLIES 8
Igor28
Message 2 of 9
Message 2 of 9
Hi @popus_czy_to_ty
Are you still experiencing issues with your laptop?
Could you provide me with the MSN reference for your device so I can check for any available BIOS updates?
Thank you.
popus_czy_to_ty
Message 3 of 9
Message 3 of 9
@Igor28 wrote:
Hi @popus_czy_to_ty
Thank you.
MSN 30033639
yes everytime when i boot linux
also it has bug which is preventing certain nvme hard drives
Seagate FireCuda 520 2TB ZP2000GV3A012 model, sometimes it sees at is should , secondly sees as "PCIE SSD" with no access to partitions.
I need reboot 2,3 times to get successully seen this hard drive. Did it make it clear?
Dnia 27 marca 2024 11:03 Hotline <hotline.email@medion.com> napisał(a):
Dear XYZ ,
If we may ask, could you please clarify what you mean by "randomly detected" in your last email in order to better assist you?
In regards to your driver updates, Windows 11 will install and update necessary driver automatically by default.
We don't think that the problem is related with the drivers from your short explanation until now.
MEDION quality survey: Please rate my email.
To reach our questionnaire please click [HERE].
Many thanks for your criticism, suggestions and your commendation.
If you require any further assistance then please do contact us.
Kind regards
XXXX
MEDION Electronics UK
https://i.postimg.cc/GrKLfkbk/IMG-20240318-203547574-1.jpg
popus_czy_to_ty
Message 4 of 9
Message 4 of 9
errors after wake up from suspend, what they are about? someone here is good at linux?
paź 27 11:40:23 Crawler-E25 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPC0.EC.MMM3], AE_NOT_FOUND (20230628/psargs-330)
paź 27 11:40:23 Crawler-E25 kernel: No Local Variables are initialized for Method [_DSM]
paź 27 11:40:23 Crawler-E25 kernel: Initialized Arguments for Method [_DSM]:  (4 arguments defined for method invocation)
paź 27 11:40:23 Crawler-E25 kernel:   Arg0:   00000000ed082312 <Obj>           Buffer(16) 56 0D E0 11 64 CE CE 47
paź 27 11:40:23 Crawler-E25 kernel:   Arg1:   00000000bed9538e <Obj>           Integer 0000000000000000
paź 27 11:40:23 Crawler-E25 kernel:   Arg2:   000000009b4e6210 <Obj>           Integer 0000000000000003
paź 27 11:40:23 Crawler-E25 kernel:   Arg3:   000000001ebf7078 <Obj>           Package 000000001ebf7078
paź 27 11:40:23 Crawler-E25 kernel: ACPI Error: Aborting method \_SB.PEP._DSM due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
paź 27 11:40:23 Crawler-E25 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPC0.EC.MMM5], AE_NOT_FOUND (20230628/psargs-330)
paź 27 11:40:23 Crawler-E25 kernel:   Arg0:   00000000530d8fe2 <Obj>           Buffer(16) 56 0D E0 11 64 CE CE 47
paź 27 11:40:23 Crawler-E25 kernel:   Arg1:   000000005ec9685a <Obj>           Integer 0000000000000000
paź 27 11:40:23 Crawler-E25 kernel:   Arg2:   00000000f95d3a7b <Obj>           Integer 0000000000000007
paź 27 11:40:23 Crawler-E25 kernel:   Arg3:   00000000e35362e2 <Obj>           Package 00000000e35362e2
paź 27 11:40:23 Crawler-E25 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPC0.EC.MMM4], AE_NOT_FOUND (20230628/psargs-330)
paź 27 11:40:23 Crawler-E25 kernel:   Arg0:   00000000500fe4b6 <Obj>           Buffer(16) 56 0D E0 11 64 CE CE 47
paź 27 11:40:23 Crawler-E25 kernel:   Arg1:   000000004e888ca8 <Obj>           Integer 0000000000000000
paź 27 11:40:23 Crawler-E25 kernel:   Arg2:   000000006a80b4cb <Obj>           Integer 0000000000000004
paź 27 11:40:23 Crawler-E25 kernel:   Arg3:   000000009b6141d0 <Obj>           Package 000000009b6141d0
paź 27 11:40:23 Crawler-E25 kernel: ACPI: EC: interrupt unblocked
paź 27 11:40:23 Crawler-E25 kernel: [drm] PCIE GART of 1024M enabled.
paź 27 11:40:23 Crawler-E25 kernel: [drm] PTB located at 0x000000F41FC00000
paź 27 11:40:23 Crawler-E25 kernel: amdgpu 0000:06:00.0: amdgpu: SMU is resuming...
paź 27 11:40:23 Crawler-E25 kernel: nvme nvme0: Shutdown timeout set to 10 seconds
paź 27 11:40:23 Crawler-E25 kernel: nvme nvme1: Shutdown timeout set to 10 seconds
paź 27 11:40:23 Crawler-E25 kernel: amdgpu 0000:06:00.0: amdgpu: dpm has been disabled
paź 27 11:40:23 Crawler-E25 kernel: amdgpu 0000:06:00.0: amdgpu: SMU is resumed successfully!
paź 27 11:40:23 Crawler-E25 kernel: nvme nvme1: 16/0/0 default/read/poll queues
paź 27 11:40:23 Crawler-E25 kernel: nvme nvme0: 16/0/0 default/read/poll queues
paź 27 11:40:23 Crawler-E25 kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
Message 5 of 9
Message 5 of 9
Hi @popus_czy_to_ty
The computer may have a problem managing the new Seagate because it is a PCIe 4.0 x4.
But it only has two slots, both PCIe3.0x4. Actually the Seagate should also be backwards compatible.
but who knows whether this is not where the inconsistency of not recognizing comes from.
Have you ever tried swapping the Seagate and the Samsung for each other? does a change then occur?
bye Fishtown
bye Fishtown
popus_czy_to_ty
Message 6 of 9
Message 6 of 9
issue with nvme's has been "solved" long time ago by buying kingston/samsung brands they were recognized. Had to loose time to send back and buy again another brand
btw. i posted some logs from linux, why did you remove them, they are irrevelant?
Message 7 of 9
Message 7 of 9
@popus_czy_to_ty
Why are you posting such a thread with this pseudo problem? Afterwards you say "bad luck", but the problem has long been solved.  ???
popus_czy_to_ty
Message 8 of 9
Message 8 of 9
on this thread is mentioned there IS bug which complaining wrong BIOS being used on my msn number and im asking if something can be done about it (probably not since product is end of life and all of you has been throttling issue up to date) second issue is only MENTION it has SECOND bug which cant recognize nvme drives...
Message 9 of 9
Message 9 of 9
@popus_czy_to_ty
About which thread  are you speaking? Not in this thread here.
And if I do understand you right, you flashed or your MSN 30033639 a wrong Bios? Which Bios? Can you give a link?
x
8 REPLIES 8
