Bios Update
5 REPLIES 5
pogbahh
Message 1 of 6
Message 1 of 6
Bios Update
Hello!
I have a Erazer Crawler E25 gaming laptop,
Serial No: 2110NH55EKQMKAP2000903
I was looking for a BIOS update if possible.
Thanks in advance :)!
5 REPLIES 5
RAZZ
Message 2 of 6
Message 2 of 6
Hi @pogbahh
Please can you provide us with the MSN number of your unit found on the underside 8 digit's long, and the current BIOS version you are using so we can verify if any BIOS updates are available.
thanks
pogbahh
Message 3 of 6
Message 3 of 6
Hi @RAZZ
MSN: 40081164
Im currently using the default BIOS that came with the system.
I havent updated it once since I bought it.
Thanks in advance
Kind regards
Message 4 of 6
Message 4 of 6
@pogbahh
The MSN you posted is the MSN of your battery !
The MSN of your Laptop is  provided on a sticker on bottom, 8 digits long and beginning with 3003 ....
And you were asked to state the Bios Version of your Laptop -> Enter Bios Setup to find out
pogbahh
Message 5 of 6
Message 5 of 6
Hi again!
My Bios Version is : 1.07.03RME1_00016
I cant find my MSN number as this sticker is not on the bottom of my laptop, but i have the motherboard serial number and product number if this helps?
Kind Regards
Message 6 of 6
Message 6 of 6
@pogbahh
Just start msinfo32.exe in Win tab + R  --> return
On the first page in the line System SKU  number you can find within the last 8 digits the MSN number.##
And edit your first post...you are not allowed to publish the serial  number!
Regards, daddle
5 REPLIES 5
