op 13.07.2023 11:49
op 13.07.2023 11:49
Hello,
I am wondering if it is better for the battery to be plugged in all the time, or to discharge to a certain percent an recharge. This is mainly for times I have the laptop on for most of the day.
Using an Erazer Crawler E10 if that makes a difference.
Thanks in advance for your responses
op 20.07.2023 13:32
op 20.07.2023 13:32
Hi @ paveley1985,
Keeping laptops plugged in for a long term may reduce battery capacity and speed up its discharge, however depending on use for example if gaming performance may be better when plugged in as certain components draw more power when under stress.
it is best not to let you battery full discharge and keep between 40% - 80% to have a better battery life
it is best to unplug when unit is unattended.
thanks
op 20.07.2023 13:32
op 20.07.2023 13:32
Hi @ paveley1985,
thanks
op 20.07.2023 13:34
