md35273 BIOS update B660H7-M20 motherboard
30 REPLIES 30
andr3y
Message 1 of 31
Message 1 of 31
Hi guys. I've got a md35273 (MSN 10024677) with MB B660H7-M20 and B660H7W0X.107 BIOS. Tried to update it to 2.12. Downloaded the BIOS from the link on this page https://community.medion.com/t5/FAQs/How-do-I-optimize-the-stability-of-my-desktop-PC-with-an-Intel/... and followed the installation instructions. After running the CMD as Admin and entering the command "UpdateBIOS.bat" all I have is this
Spoiler
C:\Users\andr3\Downloads\Bios112>UpdateBIOS.bat
C:\Users\andr3\Downloads\Bios112>if exist 123.txt del 123.txt
C:\Users\andr3\Downloads\Bios112>if exist log.txt del log.txt
C:\Users\andr3\Downloads\Bios112>if exist pass.txt del pass.txt
C:\Users\andr3\Downloads\Bios112>if exist fail.txt del fail.txt
C:\Users\andr3\Downloads\Bios112>REM SCEWIN_64.exe /o /ms "Enable VMD controller" /lang en-US /logfile: 1.txt
C:\Users\andr3\Downloads\Bios112>SCEWIN_64.exe /o /s log.txt
| AMISCE Utility. Ver 5.05.08.0009 |
| Copyright (c) 2023 AMI. All rights reserved. |
WARNING: Duplicate questions found. Only one question will be enabled in the script.
Script file exported successfully.
C:\Users\andr3\Downloads\Bios112>SPG0ECString.exe log.txt "Enable VMD controller"
????????? 123.txt
C:\Users\andr3\Downloads\Bios112>if not exist log.txt goto Double
C:\Users\andr3\Downloads\Bios112>findstr /c:"Options =*[00]Disabled" 123.txt
C:\Users\andr3\Downloads\Bios112>if 1 == 0 goto Pass
C:\Users\andr3\Downloads\Bios112>if 1 == 1 goto Fail
C:\Users\andr3\Downloads\Bios112>AFUWINx64.EXE B660H7W0X.cap /p /b /n /q /capsule
| AMI Firmware Update Utility v5.16.03.0120 |
| Copyright (c) 1985-2024, American Megatrends International LLC. |
| All rights reserved. Subject to AMI licensing agreement. |
C:\Users\andr3\Downloads\Bios112>goto end
And the update doesn't start.
Any ideas how to solve the problem? BTW checked the VMD controller option in BIOS before flashing - it's ON. If I turn it off, the system doesn't boot (BSOD)
Thanks in advance
30 REPLIES 30
Mastermind
Message 11 of 31
Message 11 of 31
Alrighty.. as promised try to get something usable til the end of the week.
Happy x-mas
Mastermind
Message 12 of 31
Message 12 of 31
Hi @andr3y  & @MHDude ,
I´ve doublechecked project details of the system and found out, that with a currently installed version V 1.07 you don´t have to use version 2.12, but version 1.12, which can be downloaded under this link.
In this case, the installation should work under the Windows interface after having extracted the .zip file & using the “Install” context menu of the B660H7W0X.inf file.
Feel free to leave a feedback if it worked out for you.
Cheers
Message 13 of 31
Message 13 of 31
@Major_ToM
Diese Empfehlung steht aber nicht differenziert in den FAQs zum Thema
-> https://community.medion.com/t5/FAQs/How-do-I-optimize-the-stability-of-my-desktop-PC-with-an-Intel/...
Ich denke mir die meisten User sind noch auf V. 1.07, damit sollte die Empfehlung  für das Board ECS B660H7-M20  die Version  2.12 zu installieren ersetzt werden durch die Empfehlung zur V. 1.12; oder zumindest nach Vorversion differenziert werden (falls es überhaupt Boards mit anderer Vorversion gibt)
Gruß, und guten Rutsch!
MHDude
Message 14 of 31
Message 14 of 31
@Major_ToM
Hey, thanks for checking everything. Just to clarify: I'm on Version 1.12 which means I can't update to Version 2.12? Is that right and Version 1.12 is the "latest" Version for my board?
Message 15 of 31
Message 15 of 31
@MHDude
I guess the 2.12 is just a misprint. Otherwise it  would be quite an illogical numbering of updates. But you never know.
Mastermind
Message 16 of 31
Message 16 of 31
Hi @MHDude ,
@MHDude  schrieb:
@Major_ToM
You hit it, There are different mainboard revisions in use which require different Bios version. So for your revision the V 1.12 is the latest and recent Bios Version.
@daddle : Appropriate FAQ will be actualised soon.
Cheers
MHDude
Message 17 of 31
Message 17 of 31
Hi @Major_ToM
Thanks for everything. Sorry that you had to endure the trouble we've caused 🙂
Cheers
andr3y
Message 18 of 31
Message 18 of 31
Hi @Major_ToM Still no luck for me. I get an installation error from Windows stating "The certificate chain was processed, but processing was stopped at the root certificate because there is no trust relationship with the trust provider."
Mastermind
Message 19 of 31
Message 19 of 31
Hi @andr3y ,
did you read my message #12 and which version did you install on your latest shot? V 1.12 or V 2.12?
Bios version V 2.12 is not compatible to mainboard with V 1.xx Bios versions.
Cheers
P.S. Appropriate FAQ has been adapted.
Vince
Message 20 of 31
Message 20 of 31
Different ROM ID:
V1  AXFE
V2  AYRT
30 REPLIES 30
