md35273 BIOS update B660H7-M20 motherboard
30 REPLIES 30
andr3y
Message 1 of 31
Message 1 of 31
Hi guys. I've got a md35273 (MSN 10024677) with MB B660H7-M20 and B660H7W0X.107 BIOS. Tried to update it to 2.12. Downloaded the BIOS from the link on this page https://community.medion.com/t5/FAQs/How-do-I-optimize-the-stability-of-my-desktop-PC-with-an-Intel/... and followed the installation instructions. After running the CMD as Admin and entering the command "UpdateBIOS.bat" all I have is this
Spoiler
C:\Users\andr3\Downloads\Bios112>UpdateBIOS.bat
C:\Users\andr3\Downloads\Bios112>if exist 123.txt del 123.txt
C:\Users\andr3\Downloads\Bios112>if exist log.txt del log.txt
C:\Users\andr3\Downloads\Bios112>if exist pass.txt del pass.txt
C:\Users\andr3\Downloads\Bios112>if exist fail.txt del fail.txt
C:\Users\andr3\Downloads\Bios112>REM SCEWIN_64.exe /o /ms "Enable VMD controller" /lang en-US /logfile: 1.txt
C:\Users\andr3\Downloads\Bios112>SCEWIN_64.exe /o /s log.txt
| AMISCE Utility. Ver 5.05.08.0009 |
| Copyright (c) 2023 AMI. All rights reserved. |
WARNING: Duplicate questions found. Only one question will be enabled in the script.
Script file exported successfully.
C:\Users\andr3\Downloads\Bios112>SPG0ECString.exe log.txt "Enable VMD controller"
????????? 123.txt
C:\Users\andr3\Downloads\Bios112>if not exist log.txt goto Double
C:\Users\andr3\Downloads\Bios112>findstr /c:"Options =*[00]Disabled" 123.txt
C:\Users\andr3\Downloads\Bios112>if 1 == 0 goto Pass
C:\Users\andr3\Downloads\Bios112>if 1 == 1 goto Fail
C:\Users\andr3\Downloads\Bios112>AFUWINx64.EXE B660H7W0X.cap /p /b /n /q /capsule
| AMI Firmware Update Utility v5.16.03.0120 |
| Copyright (c) 1985-2024, American Megatrends International LLC. |
| All rights reserved. Subject to AMI licensing agreement. |
C:\Users\andr3\Downloads\Bios112>goto end
And the update doesn't start.
Any ideas how to solve the problem? BTW checked the VMD controller option in BIOS before flashing - it's ON. If I turn it off, the system doesn't boot (BSOD)
Thanks in advance
1 ACCEPTED SOLUTION
Vince
Message 22 of 31
Message 22 of 31
30 REPLIES 30
Message 2 of 31
Message 2 of 31
@andr3y
Did you expand the  " 00_Bios_b660h7-m20_v2.zip "  in an own new folder?  Are all files expanded to the folder Bios 112? Otherwise it can't work. But I do think you have to ask @Major_ToM .
Actually the line under the first entry ->  fail:
-> C:\Users\andr3\Downloads\ Bios112> AFUWINx64.EXE B660H7W0X.cap /p /b /n /q /capsule
should have done the job.
Cheers, daddle
andr3y
Message 3 of 31
Message 3 of 31
@daddle yes, the whole archive was extracted to a folder
andr3y
Message 4 of 31
Message 4 of 31
@Major_ToM could you please help with the solution? Thanks in advance
Mastermind
Message 5 of 31
Message 5 of 31
Hi @andr3y ,
due to an IT outage we unfortunately do not have the opportunity to special replicate this case, but I´ll doublecheck, when the data is available again...
Do you have any anti virus application running on the machine, which might prevent the update from beeing executed correctly?
Cheers
andr3y
Message 6 of 31
Message 6 of 31
@Major_ToM Only the standard Microsoft Defender
Mastermind
Message 7 of 31
Message 7 of 31
Hi @andr3y ,
this is myterious, but as I said, I´ll have to investigate on this one, when our systems´re fully back.
Cheers
MHDude
Message 8 of 31
Message 8 of 31
@Major_ToM  schrieb:
Hi @andr3y ,
Cheers
@Major_ToM
I want to join the chat, because I have the same problem. I'm currently on Version 112 and want to update to the latest 212 Version. But the Update shows the same error as listed by andr3y.
I even tried to "enable Bios Update" in the .log (or was it .123) file.
Mastermind
Message 9 of 31
Message 9 of 31
Hi @MHDude ,
thank you for your feedback. I´ll try to provide further information until the end of the week. @andr3y : Could you plerase confirm, that the issue is still present with your machine?
Cheers and a happy x-mas
andr3y
Message 10 of 31
Message 10 of 31
Hello @Major_ToM
Tried to update the BIOS again today - no luck, got the same message with error as earlier 😞
Happy Christmas!
30 REPLIES 30
