Removing hard drive
9 ANTWOORDEN 9
Thjorin
Bericht 1 van 10
9.428 Weergaven
Bericht 1 van 10
9.428 Weergaven
Removing hard drive
Hey, i have a question, I'm selling my mom's old PC, but would like to remove hard drive, but don't rly know how to do it with this one? Can u help?
9 ANTWOORDEN 9
Bericht 2 van 10
9.417 Weergaven
Bericht 2 van 10
9.417 Weergaven
@Thjorin
It would be helpful if you give us a name and the MSN number of your PC.
But generally speaking, the harddisk ist fixed in this cage; I guess one can mobilize this cage, possibly it is hooked into the front panel and fixed itself with a screw.
After this step you will find mostly two screws on both sides of the cage, qhich mounts the HDD:
 Cheers, daddle
Thjorin
Bericht 3 van 10
9.411 Weergaven
Bericht 3 van 10
9.411 Weergaven
The only type of screws are those small ones that i can't unscrew with any screwdriver i try
Thjorin
Bericht 4 van 10
9.410 Weergaven
Bericht 4 van 10
9.410 Weergaven
  •  and here is the other thing
Edit by Admin:
Picture of type plate rejected due to serial number (personal data).
Relevant number: Art.-Nr. (MSN) 10018824
Bericht 5 van 10
9.406 Weergaven
Bericht 5 van 10
9.406 Weergaven
@Thjorin
The pictures can not be seen by now.
But possibly it are just some plastic plugs or pins, which you could extract with a small plier o forceps.
Thjorin
Bericht 6 van 10
9.405 Weergaven
Bericht 6 van 10
9.405 Weergaven
I did remove the plastic pins, but the thing is still held by those tine round head screws that i can't do with any screwdriver i tried
Bericht 7 van 10
9.397 Weergaven
Bericht 7 van 10
9.397 Weergaven
@Thjorin
I do think those are rivets, which don't have to be removed. Possibly the HDD is hooked in on one síde, so it must be lifted up on the  opposite side to be releived from the little metal hooks, which are plugged into the screw holes on this  one long side.
An other possibility could be, to dismount the complet e metal cage
Thjorin
Bericht 8 van 10
9.383 Weergaven
Bericht 8 van 10
9.383 Weergaven
 the drive won't move any way i try, and the whole casing is being held down with rivets
Bericht 9 van 10
9.379 Weergaven
Bericht 9 van 10
9.379 Weergaven
@Thjorin
Well, then I don't know anymore. Your picture will be seen to other users only tomorrow.
But if you can't handle this, go to a PC repairshop round the corner. For the technicians there  it is only a question of minutes.
As an alternativ you could destroy the contents of the hard disk to make them unreadable with disk cleaning programs like OW Schredder or Erazer.
mle
Bericht 10 van 10
2.745 Weergaven
Bericht 10 van 10
2.745 Weergaven
There are 2 screws at the bottom of the case you have to remove
1 screw is hard to see :), i didn't see it either at first
9 ANTWOORDEN 9
