Removing hard drive
9 RÉPONSES 9
Thjorin
Message 1 sur 10
8 304 Visites
Message 1 sur 10
8 304 Visites
Removing hard drive
Hey, i have a question, I'm selling my mom's old PC, but would like to remove hard drive, but don't rly know how to do it with this one? Can u help?
Balises (2)
9 RÉPONSES 9
Message 2 sur 10
8 293 Visites
Message 2 sur 10
8 293 Visites
@Thjorin
It would be helpful if you give us a name and the MSN number of your PC.
But generally speaking, the harddisk ist fixed in this cage; I guess one can mobilize this cage, possibly it is hooked into the front panel and fixed itself with a screw.
After this step you will find mostly two screws on both sides of the cage, qhich mounts the HDD:
 Cheers, daddle
Thjorin
Message 3 sur 10
8 287 Visites
Message 3 sur 10
8 287 Visites
The only type of screws are those small ones that i can't unscrew with any screwdriver i try
Thjorin
Message 4 sur 10
8 286 Visites
Message 4 sur 10
8 286 Visites
  •  and here is the other thing
Edit by Admin:
Picture of type plate rejected due to serial number (personal data).
Relevant number: Art.-Nr. (MSN) 10018824
Message 5 sur 10
8 282 Visites
Message 5 sur 10
8 282 Visites
@Thjorin
The pictures can not be seen by now.
But possibly it are just some plastic plugs or pins, which you could extract with a small plier o forceps.
Thjorin
Message 6 sur 10
8 281 Visites
Message 6 sur 10
8 281 Visites
I did remove the plastic pins, but the thing is still held by those tine round head screws that i can't do with any screwdriver i tried
Message 7 sur 10
8 273 Visites
Message 7 sur 10
8 273 Visites
@Thjorin
I do think those are rivets, which don't have to be removed. Possibly the HDD is hooked in on one síde, so it must be lifted up on the  opposite side to be releived from the little metal hooks, which are plugged into the screw holes on this  one long side.
An other possibility could be, to dismount the complet e metal cage
Thjorin
Message 8 sur 10
8 259 Visites
Message 8 sur 10
8 259 Visites
 the drive won't move any way i try, and the whole casing is being held down with rivets
Message 9 sur 10
8 255 Visites
Message 9 sur 10
8 255 Visites
@Thjorin
Well, then I don't know anymore. Your picture will be seen to other users only tomorrow.
But if you can't handle this, go to a PC repairshop round the corner. For the technicians there  it is only a question of minutes.
As an alternativ you could destroy the contents of the hard disk to make them unreadable with disk cleaning programs like OW Schredder or Erazer.
mle
Message 10 sur 10
1 621 Visites
Message 10 sur 10
1 621 Visites
There are 2 screws at the bottom of the case you have to remove
1 screw is hard to see :), i didn't see it either at first
9 RÉPONSES 9
