My First Post
17 ANTWOORDEN 17
bigman1974
Bericht 1 van 18
13.657 Weergaven
Bericht 1 van 18
13.657 Weergaven
My First Post
Hello Everyone
I found it very difficult to penetrate the username/password section of the forum but I hope I'm in business now. I'm having problems with my Akoya laptop,
since I updated from Windows 7 to Windows 10, and Im hoping there's someone able to help. I will put all the details in my next post.
17 ANTWOORDEN 17
Gehringer
Retired
Bericht 2 van 18
8.293 Weergaven
Bericht 2 van 18
8.293 Weergaven
Hi @bigman1974 and welcome to the FORUM!
We look forward to receive your next message!
Regards,
Gehringer
bigman1974
Bericht 3 van 18
8.279 Weergaven
Bericht 3 van 18
8.279 Weergaven
Hi
When I got a clean install of Windows 10 (previously 7) I had a few hitches and after tech help from Microsoft, Im left with the display staying blank when it should be displaying the lock screen. Microsoft blame the Bios, so I set about trying to find a Bios update.
Inputting MSN 30012974 I get version 3.02 on the Medion drivers list, but when I tried to run the unpacked .exe, I got an error saying it could not run. My current bios version is 209 dated 4/7/2011 (simbios version 2.6)
Should this work on my laptop or could I be doing something wrong?
Any help would be appreciated.  :o))
Bericht 4 van 18
8.271 Weergaven
Bericht 4 van 18
8.271 Weergaven
@bigman1974
The downloaded exe is a container file, which you first have to unpack. When you double click the exe, a small windows open (it might hide behind your Browser page), in which you have to click on the extract button.The unpacked files reside in a folder C:\Medion. Then start the unpacked file A15MD.302.EXE with rightclick as admin.
Battery should be above 50%, and the power supply should be connected to the wall outlet.
Regards, daddle
bigman1974
Bericht 5 van 18
8.260 Weergaven
Bericht 5 van 18
8.260 Weergaven
Hi Daddle and thanks for your response.
I did extract the downloaded file to C://Medion, giving me the executable  A15MD.302.EXE, and it was running that file that gave me the "can't run" error.
I did find some conflicting information about the environment in which to run it, with some people advising against running it from Windows. Medion said this was ok as long as there were no programs running in background, but I found a long list of these at start up, some of which I wasn't allowed to close.
So I have two questions:
1. Can I be certain that this bios update is OK to install and won't do any damage ? (I am not talking about power issues).
2.  What is the safest environment to run the update (e.g. Safe Mode, Command Prompt) ?.
I did look at the Command Prompt option, but in Windows 10 but that has just an X:/ directory and I could not find the C:/Medion folder. Also, I don't think that the in situ Bios itself has a flash utility.
Please advise if you are able to help with my questions.
Thank you  🐵
Bericht 6 van 18
8.257 Weergaven
Bericht 6 van 18
8.257 Weergaven
@bigman1974
Did you run the exe with rightclick on it as admin? Second was your LAptop at least
50% charged and connected to the Power Supply?
And all the programs running in the background you can close; those you cannot close do not harm normallly; or go to msconfig and choose safe start
bigman1974
Bericht 7 van 18
8.247 Weergaven
Bericht 7 van 18
8.247 Weergaven
Hi Daddle, and thanks a lot for your advice.
1. The laptop would have been close to 100%, as the power supply has been connected continuously for some time (its fully charged at this moment)
2. No, I didn't "run as Administrator". I will try that.
3. I will try the Diagnostic Startup
regards, bigman1974
Bericht 8 van 18
8.244 Weergaven
Bericht 8 van 18
8.244 Weergaven
@bigman1974
Why not? Thats what I wrote. It's useless if one supports and the other doesn't stick to  it!
bigman1974
Bericht 9 van 18
8.236 Weergaven
Bericht 9 van 18
8.236 Weergaven
"Why not? Thats what I wrote. It's useless if one supports and the other doesn't stick to  it!"
The above came as a surprise, but you may not have realised that I haven't attempted to run the program again since you posted the administrator advice. I have run it as administrator now, and I still got the error message "No Bios can be flashed".
I also checked that the laptop was fully charged.  I  had to run it in Safe Mode because of the blank screen problem at startup/restart. Using the Diagnostic startup didn't allow me to "yo-yo" in and out of sleep mode (my work around to get the display back on).
regards, bigman1974
Bericht 10 van 18
8.231 Weergaven
Bericht 10 van 18
8.231 Weergaven
@bigman1974
Well, the Bios-Update is from 2013 and was designed for Win 8.1. Maybe your Windows is by now Win 10, and that is why it does not work.
You could make a image from your status quo, do a restore with PowerRecover, if applicable, to get Win 8.1, and do the Update. May be then it functions. After that restore your actual image.
But your blank screen problem says something is wrong with your setup. Did you try "Reststrom Entladung"? Get the rest of electric load (charge) off your mainboard?:
1. Disconnect from wall outlet
2. Take of the battery
3. Press power button for at least 15 seconds
4. Replace battery and power supply
5. Restart the PC
If your battery is fixed within the case, try to dismount it. If this does not work, run the battery completely empty by opening bios screen and connect it additionallly to an external harddisk, the mechanical type, not a ssd, to drain the battery too.
Regards, daddle
Edit: Typo
17 ANTWOORDEN 17
