Medion erazer msn 10024443 doesn't display anything
13 ANTWORTEN 13
Jeffherckens
Nachricht 1 von 14
5.028 Aufrufe
Nachricht 1 von 14
5.028 Aufrufe
Hello
I just bought my new erazer desktop msn 10024443. I switched it on for the first time with the hmdi of the monitor connected to the graphics card but the display screen doesn't show anything. I retried multiple times but no success.
Can anyone help?
13 ANTWORTEN 13
Nachricht 11 von 14
1.498 Aufrufe
Nachricht 11 von 14
1.498 Aufrufe
@Jeffherckens
Why can't you people first check all hints before answering so quickly?
You could try with a TV HDMI in port.
Pressing Del doesn't help if there is no picture, Did you check with both ports,on video card and mainboard ?
What about beeping sounds???
If there are no beeping sounds, at least the bios recognizes a video chip, so one should be able to get a picture at least.
Jeffherckens
Nachricht 12 von 14
1.491 Aufrufe
Nachricht 12 von 14
1.491 Aufrufe
Hi @daddle ,
I connected the pc to my TV via hdmi.
I first tested the hmdi port on the video card --> no result.
I tested the hmdi port on the main board --> no result.
I can confirm that there are no beeping noises.
Nachricht 13 von 14
1.487 Aufrufe
Nachricht 13 von 14
1.487 Aufrufe
@Jeffherckens
Waituing for your picture.
Try a different, a NEW  HDMI cable
Check the seating of the video card. It is a heavy one, it might have slipped out of the correct seating in the slot. Lock it.with the bracket lock at the end of the card, which must be pressed Down or Up to lock; I am just not quite sure.
Best would be to remove the video card, and put it in anew.
What  about the power cables coming  from the PSU ? Are they connecte to the video card. Or may be the two cables caming from the video  +card  dangling loosely are the additional power supply, the video card needs.
But I haven't heard so far, this comes from or is provided from the mainboard.
Dont you have a local computershop, which can check  this on the fly? For a professional it is one look in the opened case, to see if all cables  are properly fitted.
Nachricht 14 von 14
1.482 Aufrufe
Nachricht 14 von 14
1.482 Aufrufe
@Jeffherckens
The RAM-Modules looking a bit crooked, as if not  completely pressed in. On the pictures the left one.
Is on the card a connector, into the loose cable-plugs would fit?
The one with the bigger black plug looks as if  it had to be connected to the motherboard itself? But I am not at all sure of this.
Maybe someone  with bigger experience with graphic cards, may be @Kill_Bill , could help you there.
13 ANTWORTEN 13
