Medion Engineer X32 - DDR5 4800MHz RAM running at 4400Mhz + how to update BIOS + RGB Control
11 RÉPONSES 11
PeterB79
Message 1 sur 12
37 748 Visites
Message 1 sur 12
37 748 Visites
Hi all,
I've just purchased a Medion Engineer X32 and I have a few questions, I'm hoping you can help.
Firstly, the Samsung 16GB DDR5 4800MHz  is only running at 4400Mhz.
I've looked in the BIOS (which seems very out dated) and can find nowhere to adjust the multipliers or enable XMP.
That brings me to the BIOS version, it's very old (760H7EMW0X.102, from 27/12/2022), where can I find an update, should one exist?
The board seems to be an ECS B760H7-EM V1.0. I've checked the ECS site and it doesn't exist. Does anyone have a link to this board? Even Google isn't too helpful here, is it a custom board for Medion?
I've checked the Medion site and there's no downloads for this machine on the support page.
And finally the RGB, how do I turn it of, or at least fix the colour?
Thanks in advance.
1 SOLUTION APPROUVÉE
Solutions acceptées
Message 4 sur 12
21 135 Visites
Message 4 sur 12
21 135 Visites
Hello and welcome
Please state your MSN number from the computer.
try this software to change the colors:
https://cdn.medion.com/downloads/software/MEDION_RGB_Light_Center.zip
bye Fishtown
11 RÉPONSES 11
Message 2 sur 12
21 144 Visites
Message 2 sur 12
21 144 Visites
@PeterB79
Welcome here.
... can find nowhere to adjust the multipliers or enable XMP.
Das ist normal with Medion PC. XMP profiles are blocked. The RAM usually runs for safety reasons about  10 % less the specs. The Board usually is a MedionOEM  Board
About a new Bios you should ask a moderator, e.g. @Major_ToM , which will be informed by now.
Cheers,  daddle
PeterB79
Message 3 sur 12
21 141 Visites
Message 3 sur 12
21 141 Visites
Thank you for the reply, I'll wait to see if a moderator replies in the next couple of days, if not I'll contact one of them.
I just spotted that I posted this in the wrong forum...whoops!
Message 4 sur 12
21 136 Visites
Message 4 sur 12
21 136 Visites
Hello and welcome
bye Fishtown
PeterB79
Message 5 sur 12
21 110 Visites
Message 5 sur 12
21 110 Visites
Hi Fishtown,
The MPN is: 10025109.
Thank you for the suggestion and link, I'll try that later today.
Message 6 sur 12
21 102 Visites
Message 6 sur 12
21 102 Visites
Hi @PeterB79 ,
I´ll check for the information and a current BIOS version and come back ASAP
Cheers
PeterB79
Message 7 sur 12
21 091 Visites
Message 7 sur 12
21 091 Visites
Brilliant, thank you @Major_ToM
PeterB79
Message 8 sur 12
21 077 Visites
Message 8 sur 12
21 077 Visites
@Fishtown
The light centre works, thank you for that. 🙂
Now I just need to figure out how to get the RAM running at full speed.
I've upgraded to 32GB 6400MHz RAM, but still it's only running at 4400MHz.
Message 9 sur 12
20 972 Visites
Message 9 sur 12
20 972 Visites
Hi @PeterB79 , @Fishtown , @daddle ,
just received a feedback from tech dept.,which sounds as: "Our ECS mainboards are (regardless of the XMP settings) permanently set to 4400Mhz."
I take this as a fact and decide not to comment on it, not being aware of the complete technical background.
Cheers
PeterB79
Message 10 sur 12
20 956 Visites
Message 10 sur 12
20 956 Visites
@Major_ToM
Thank you for finding out and getting back to me. It's not the answer I was hoping for, but your help is appreciated. I'll probably swap out the main board later down the line, for now the performance is fine.
Did they say whether there was an update to the old BIOS version?
11 RÉPONSES 11
