Medion Engineer X32 - DDR5 4800MHz RAM running at 4400Mhz + how to update BIOS + RGB Control
11 ANTWORTEN 11
PeterB79
Nachricht 1 von 12
39.183 Aufrufe
Nachricht 1 von 12
39.183 Aufrufe
Hi all,
I've just purchased a Medion Engineer X32 and I have a few questions, I'm hoping you can help.
Firstly, the Samsung 16GB DDR5 4800MHz  is only running at 4400Mhz.
I've looked in the BIOS (which seems very out dated) and can find nowhere to adjust the multipliers or enable XMP.
That brings me to the BIOS version, it's very old (760H7EMW0X.102, from 27/12/2022), where can I find an update, should one exist?
The board seems to be an ECS B760H7-EM V1.0. I've checked the ECS site and it doesn't exist. Does anyone have a link to this board? Even Google isn't too helpful here, is it a custom board for Medion?
I've checked the Medion site and there's no downloads for this machine on the support page.
And finally the RGB, how do I turn it of, or at least fix the colour?
Thanks in advance.
Nachricht 4 von 12
22.201 Aufrufe
Nachricht 4 von 12
22.201 Aufrufe
Hello and welcome
Please state your MSN number from the computer.
try this software to change the colors:
https://cdn.medion.com/downloads/software/MEDION_RGB_Light_Center.zip
bye Fishtown
11 ANTWORTEN 11
Nachricht 2 von 12
22.210 Aufrufe
Nachricht 2 von 12
22.210 Aufrufe
@PeterB79
Welcome here.
... can find nowhere to adjust the multipliers or enable XMP.
Das ist normal with Medion PC. XMP profiles are blocked. The RAM usually runs for safety reasons about  10 % less the specs. The Board usually is a MedionOEM  Board
About a new Bios you should ask a moderator, e.g. @Major_ToM , which will be informed by now.
Cheers,  daddle
PeterB79
Nachricht 3 von 12
22.207 Aufrufe
Nachricht 3 von 12
22.207 Aufrufe
Thank you for the reply, I'll wait to see if a moderator replies in the next couple of days, if not I'll contact one of them.
I just spotted that I posted this in the wrong forum...whoops!
Nachricht 4 von 12
22.202 Aufrufe
Nachricht 4 von 12
22.202 Aufrufe
Hello and welcome
bye Fishtown
PeterB79
Nachricht 5 von 12
22.176 Aufrufe
Nachricht 5 von 12
22.176 Aufrufe
Hi Fishtown,
The MPN is: 10025109.
Thank you for the suggestion and link, I'll try that later today.
Nachricht 6 von 12
22.168 Aufrufe
Nachricht 6 von 12
22.168 Aufrufe
Hi @PeterB79 ,
I´ll check for the information and a current BIOS version and come back ASAP
Cheers
PeterB79
Nachricht 7 von 12
22.157 Aufrufe
Nachricht 7 von 12
22.157 Aufrufe
Brilliant, thank you @Major_ToM
PeterB79
Nachricht 8 von 12
22.143 Aufrufe
Nachricht 8 von 12
22.143 Aufrufe
@Fishtown
The light centre works, thank you for that. 🙂
Now I just need to figure out how to get the RAM running at full speed.
I've upgraded to 32GB 6400MHz RAM, but still it's only running at 4400MHz.
Nachricht 9 von 12
22.038 Aufrufe
Nachricht 9 von 12
22.038 Aufrufe
Hi @PeterB79 , @Fishtown , @daddle ,
just received a feedback from tech dept.,which sounds as: "Our ECS mainboards are (regardless of the XMP settings) permanently set to 4400Mhz."
I take this as a fact and decide not to comment on it, not being aware of the complete technical background.
Cheers
PeterB79
Nachricht 10 von 12
22.022 Aufrufe
Nachricht 10 von 12
22.022 Aufrufe
@Major_ToM
Thank you for finding out and getting back to me. It's not the answer I was hoping for, but your help is appreciated. I'll probably swap out the main board later down the line, for now the performance is fine.
Did they say whether there was an update to the old BIOS version?
11 ANTWORTEN 11
