MS-7728 Wake-On-LAN
8 ANTWOORDEN 8
Teratogenic
Bericht 1 van 9
2.888 Weergaven
Bericht 1 van 9
2.888 Weergaven
MS-7728 Wake-On-LAN
Hello,
I'm having a problem where there's no option to enable Wake-On-LAN in my BIOS. I also purchased an internal network card (TP-Link TG-3468).
It's also possible that the motherboard doesn't support it... I hope someone can help me.
8 ANTWOORDEN 8
Bericht 2 van 9
2.880 Weergaven
Bericht 2 van 9
2.880 Weergaven
@Teratogenic
Hi, I am sorry.
If it isn't implemented in your actual Bios, it is not possible to use WOL.
Bye, daddle
Bericht 3 van 9
2.855 Weergaven
Bericht 3 van 9
2.855 Weergaven
Hi @Teratogenic and welcome
Set deep S4/S5 to disabled in the BIOS under "Advanced" " Power Management Setup"
bye Fishtown
jack30walker
Bericht 4 van 9
2.491 Weergaven
Bericht 4 van 9
2.491 Weergaven
If you can’t find any Wake-On-LAN option in your BIOS, it’s possible that your motherboard simply doesn’t support it. Some boards only offer settings like “Power on by PCI-E” or “Resume by LAN,” and if none of these appear, WOL may not be available. Your TP-Link TG-3468 network card does support Wake-On-LAN, but it still requires BIOS-level support to function. The best next step is to check your motherboard’s manual or provide the exact model so we can confirm whether WOL is supported and see if there are alternative power or PCI-E settings you might need to enable.
Bericht 5 van 9
2.478 Weergaven
Bericht 5 van 9
2.478 Weergaven
@jack30walker  @Fishtown
In post 2 I gave the correct answer already::
@daddle  schrieb:
Hi, I am sorry. If it isn't implemented in your actual Bios, it is not possible to use WOL
I'm getting pretty fed up now. In post 2 I gave the correct answer. Then these smart guys come along and have to chime in with their two cents.. And just so they can post something themselves. It's almost becoming a pattern.
As for the new participant, he has a strange alias. I wouldn't be surprised if he  added an unauthorized link later while using his editing rights.
Bye, daddle
Bericht 6 van 9
2.471 Weergaven
Bericht 6 van 9
2.471 Weergaven
Hi @daddle
Calming to the nerves: valerian
https://community.medion.com/t5/Desktop-PC-All-In-One/Medion-MD-Business-G530500-8225DE-BIOS-Wake-On...
bye Fishtown
Bericht 7 van 9
2.460 Weergaven
Bericht 7 van 9
2.460 Weergaven
@Fishtown
Du vergleichst einen anderen Rechner mit anderem Bios- und LAN-Chip. Wenn es nicht im Bios (und im Netzteil über standby-versorgung) angelegt ist, hilft das nichts.  Es fehlen die Punkte  EUP Function und  Resume by   PME.
Des weiteren hatte  ich in Post 2 in Conditional sinngemäß geschrieben: " Falls das Bios WOL nicht unterstützt..( bzw es nicht im Bios implementiert ist)"
Und meine Nerven sind bestens. Da brauche ich keine Schützenhilfe. Etwas arrogant diese Reaktion  von dir,  oder?
 Edit:  Typo, Ergänzung
Bericht 8 van 9
2.454 Weergaven
Bericht 8 van 9
2.454 Weergaven
Hi @daddle
You're really good.
You can predict a user's intention to post illegal links just from their username. You should join the cybercrime unit.
And you know it's a different computer and a different BIOS, even though the original poster didn't mention it. Impressive.
Since you know the computer and the BIOS, why don't you tell us its name?
And "give your two cents" isn't exactly your usual phrase, is it? So much for being "arrogant."
End, bye Fishtown
Bericht 9 van 9
2.442 Weergaven
Bericht 9 van 9
2.442 Weergaven
@Fishtown
Lerne du mal die korrekte  Bedeutung eines Konjunktivs in der deutsche Sprache. Ich habe nicht  vorher gesagt (predicted), sondern nur die Möglichkeit angedeutet.  Spammende User benutzen oft  diese Art der Aliasnamengestaltung in einer 3er Gruppierung.
Fällt einem argumentativ nichts mehr ein, operiert man  mit falschen Vergleichen. Bedenklich.
Da Ich schon wie gesagt meine Feststellung conditional gemacht habe (heißt bedingt, da dies anscheinend nicht bekannt), und der User nicht Erfolg  meldete, es ginge doch (bzw er hatte schon im Eingangspost gesagt, er finde keine Einstellung für WOL im Bios), wird es auch mit WOL nicht funktionieren.
Dein eigenes Argument, wir wüssten doch nicht genau welches Board der User habe, richtet sich aber um so mehr gegen dich selber.  Dein Heranziehen eines Posts aus einem anderem Thread, also mit einer Lösung für ein Board, von dem du aber selber nur  voraussetzt, es sei das Gleiche.
Denn du unterstellst mit deinem Link in Post 3 , es handele sich um dieselbe Boardversion, selbes Bio und die gleiche WOL fähige Netzwerkkarte.
Dazu dein Tipp mit Umstellung von S4 /S5, unkritisch aus dem Post von Andi im anderem Thread übernommen. Das ist doch Alles zu deiner eigenen Aussage konträr,  wir wüssten doch gar nicht welches Board der User hier im Thread habe. Sieh deinen Text:
@Fishtown  schrieb:
And you know it's a different computer and a different BIOS, even though the original poster didn't mention it? Impressive.
Daher  formulierte  ich es conditional.
Schon wieder so eine manipulative Verdrehung, man könnte auch bewusste Falschaussage  oder sogar an Lüge denken, denn ich habe nicht gesagt ich wüsste das (siehe oben).
Und dann noch versuchen das ins Lächerliche zu ziehen trifft dich doch selber. Merkst du das nicht?
Edit: Typo
8 ANTWOORDEN 8
