MEDION H110H4-EM upgrade BIOS
5 RÉPONSES 5
oruiz73
Message 1 sur 6
20 716 Visites
Message 1 sur 6
20 716 Visites
Hello everyone.
I have a PC of the Microstar brand, with an Intel I7 6700 mounted on the following motherboard, a MEDION H110H4-EM, and the BIOS is the following, AMERICAN MEGATRENDS INC. 110EMW0X.102 from 04-03-2016.
1. Can you tell me if this board is ATX, microATX, etc.? I want to change the cabinet and I don't know which to choice
2. I would like to know what is the most current BIOS that exists to install it and where to find it, in case you think it is interesting to change it.
3. I would also like to know until which DRAM frequency I can install for optimal operation, I currently have running an 8mb slot at 2133mhz.
Thank you very much for your time and answers.
5 RÉPONSES 5
Gehringer
Retired
Message 2 sur 6
20 470 Visites
Message 2 sur 6
20 470 Visites
Hi @oruiz73 , welcome to the FORUM!
Can you please provide me the MSN number of your PC?
An MSN number is an eight-digits identifier that you can find printed in a label behind or underneath the product.
Regards
Gehringer
oruiz73
Message 3 sur 6
20 405 Visites
Message 3 sur 6
20 405 Visites
Hello @Gehringer and thanks for your reply.
First of all, sorry for the delay in answering.
I tried to find that number and I only found a number called MB: 20060054. I think it's probably correct but I don't know for sure.
Is this the number you were asking for?
Thank you!
Gehringer
Retired
Message 4 sur 6
20 401 Visites
Message 4 sur 6
20 401 Visites
Hi @oruiz73 ,
I have just realized that your PC is not Medion and this is the reason why you haven't found the MSN number in it.
I am sorry.
In this case, I've done a research and I found out that there are 2 updates available for your MB on this Medion website
To answer all your other questions, unfortunately, I could only find third-parties websites for which Medion can't take responsibility.
Just use the following terms in your search MB ECS H110H4-EM DDR4 S1151 IPO W10 dram or just H110H4-EM.
Be aware that there is at least another similar model name which is H110H4-EM2, so don't make any mistakes in your search
Regards,
Gehringer
Message 5 sur 6
20 390 Visites
Message 5 sur 6
20 390 Visites
@Gehringer @oruiz73
On a PC actually the label with the MSN is not "behind" on the back of the PC, but often it is on a sticker on the bottom underneath.
And isn't a Microstar not a  Medion brand as well?
Regards, daddle
Message 6 sur 6
20 374 Visites
Message 6 sur 6
20 374 Visites
Hi @oruiz73
i found this one
PC Microstar Prof.P4404 D / C453 ES MSN: 10021728
Intel i7 6700/ 8Gb DDR4 /1Tb 3,5" Sata2 / Power Supply 400 Watt / Graphic GTX 1060
Mainboard MSN: 20060054 = H110H4-EM
Can that be yours ?  see:
if you want to find the name of the product:
open cmd , copy and paste = wmic csproduct get name     and then press enter
is it the same name?
for serial number, copy and paste = wmic bios get serialnumber     and then press enter
it´s the serial number ,not the MSN number
sent @Gehringer the serial number per Mail, when you have lucky, he can help
bye Fishtown
5 RÉPONSES 5
