Elite group b660h7-m20 bios update
9 REPLIES 9
Gadta89
Message 1 of 10
Message 1 of 10
Hello,
after waste 1 month to chat with useless support on medion and etc group I create topic here (don’t think will receive adequate help cuz support is bad bad and bad.
I have medion bandit p20(never will buy again medion product) with  motherboard b660h7-m20 in official
website on etc group have latest bios update to change microcode for 13-14th generation intel,but this bios is not possible to update cuz bios version on my board is made from medion. Answer is when medion planing create update  for bios to change microcode to 0x12b ? Or is time to put this motherboard in bin and buy to some normal brand where bios update cost 1 minute to do .
thank you
9 REPLIES 9
RAZZ
Message 2 of 10
Message 2 of 10
Hi  ,
please open the side panel of the unit and locate the white label towards the back, you will need to determine the BIOS update on your system
if the label, says 1.0 use
https://www.gigabyte.com/Motherboard/Z790-AORUS-ELITE-AX-rev-10/support#support-dl-driver
If it says ...
https://www.gigabyte.com/Motherboard/Z790-AORUS-ELITE-AX-rev-1x/support#support-dl-driver
hope this helps
MEDION DISCLAIMER
 Medion do not accept any responsibility for damage or lost of data in case of any error, caused by the execution of updates to the BIOS and the unit
Upgrades and modifications to your PC/laptop should only be carried out by a qualified specialists. If you do not have the necessary qualifications, have the work carried out by a qualified service technician
Thanks
@Gadta89
RAZZ
Message 3 of 10
Message 3 of 10
hi
updating missing text
if the label, says use
MEDION DISCLAIMER
Gadta89
Message 4 of 10
Message 4 of 10
Hi,
how to update after download. No options in bios to flash...
Gadta89
Message 5 of 10
Message 5 of 10
Hi,
for 1 milion time im not with Gygabite  motherboard pls read correct.
this is my stupid motherboard https://www.ecs.com.tw/en/Product/Motherboard/B660H7-M20/specification
RAZZ
Message 6 of 10
Message 6 of 10
Hi @Gadta89
This is a forum where people are here to help give advice and assist each other, please reframe from comments like this.
We will try and assist you further.
Thanks
RAZZ
Message 7 of 10
Message 7 of 10
please can you supply the below info from your unit
MSN -
S/N-
Current BIOS version-
thanks
Gadta89
Message 8 of 10
Message 8 of 10
MSN:10025150
Serial number:01100251500100042
B660H7W0X.212 11.09.2024
 in official website is released lates bios where change microcode but I can’t update cuz my bios is from medion.
Question is when medion planing create same update ?
Gadta89
Message 9 of 10
Message 9 of 10
Also have this problemAlso have this problem
Gadta89
Message 10 of 10
Message 10 of 10
Hello,
did you find any fix for this ?
9 REPLIES 9
