EM2 system firmware 113 error
29 RÉPONSES 29
LOTGS
Message 1 sur 30
47 785 Visites
Message 1 sur 30
47 785 Visites
Hi there,
I've just been on my PCs device manager and noticed an error symbol over the Medion EM2 system firmware 113 (see picture below). I was wondering if anyone knows what this it? Should I be concerned and what could I try to fix it? The PC is an Erazer Engineer P10 and it seems to be running fine. I've tried updating the driver for that device but it hasn't remedied the issue.
Thanks in advance!
29 RÉPONSES 29
LOTGS
Message 21 sur 30
12 963 Visites
Message 21 sur 30
12 963 Visites
Thanks @daddle
That's worked, I've successfully updated the Bios!
The only thing now is the original problem (Medion EM2 System Firmware 113 device cannot start (code 10)) is still present. Do you happen to have any suggestions for how this could be resolved now the Bios is updated? Much appreciated!
Message 22 sur 30
12 960 Visites
Message 22 sur 30
12 960 Visites
@LOTGS
No, I am sorry. I do not know. You should ask a moderator, eg @Major_ToM for this. He suggested already to reinstall Windows from scratch.
This you can do with Power Recover, or with a Windows Install USB stick, created with the MediaCreationTool from Microsoft, or for Windows 11  or for Windows 10
Cheers, daddle
Mastermind
Message 23 sur 30
12 949 Visites
Message 23 sur 30
12 949 Visites
Hi @LOTGS ,
I think we (means: you) have multiple options now.
  • Option 1 would be a fresh and proper installation like I described a couple of posts before using the MCT.
  • Option 2 is trying to execute a Bios Update to version 1.16, which can be downloaded right here
    This update might be a bit challenging, because at first you have to ensure, that the Intel Management Engine ist deactivated, like Lolopapadepo described  in the french Community
    Furthermore ist might appear, that during the update the Windows key will be overwritten, so you have to check, whether the Windows product key is displayed on your screen.
    If the Windows product key is not displayed, be sure to stop the update ("N" key), restart the PC and then perform the update again. If the Windows product key was read out, it is saved in the file "DPK.txt" on the desktop. Please print out this file or save it permanently in another way.
    If I´m not completely wrong @multilaf already did this successfully but all in all you fore sure have to pay attention to execute the update correctly
In case you need further help, you´ll find it here 🙂
Cheers
LOTGS
Message 24 sur 30
12 924 Visites
Message 24 sur 30
12 924 Visites
Thanks @Major_ToM
1.16 is the version of the Bios that I already updated to and that hasn't resolved the issue. I'm guessing that only leaves me with option 1 that you described, but that still seems to be quite a drastic and hugely inconvenient course of action.
Do you know if this issue likely to cause any practical problems in future? The PC seems to be running fine at the moment...
Thanks.
Mastermind
Message 25 sur 30
12 917 Visites
Message 25 sur 30
12 917 Visites
Hi @LOTGS ,
with 1.16 you definetely have the recent version and if your system has no obvious failures, I´d continue working that way.
Cheers
Sir_burp
Visitor
Message 26 sur 30
29 160 Visites
Message 26 sur 30
29 160 Visites
@LOTGS
I just finished reading the solutions provided to fix the Medion EM2 System firmware 113 issue, and after installing to the latest bios version (1.16) using the method explained and being greeted with the firmware issue still being 'apparently' present, I instinctively downgraded the driver of EM2 only to update it again and voila.
Properties -> Driver -> Previous Driver?(3th option) -> Update driver? (2nd option)
Hope it's still worth something 🙂
LOTGS
Message 27 sur 30
12 717 Visites
Message 27 sur 30
12 717 Visites
Thank you @Sir_burp!
That's done the trick for me too. I rolled the driver back, and it's still saying that I'm running the best drivers when I try to update it again, but whatever: the warning message has gone and the device is working properly now. Who'd have though it would be somethning so simple?
Gamkrelidz3
Message 28 sur 30
11 681 Visites
Message 28 sur 30
11 681 Visites
hello, i need To update Bios can you told me link for download? Medion akoya e62031 (md 34460)
msn 10024286
serial 10024286010200
kuba
Message 29 sur 30
7 860 Visites
Message 29 sur 30
7 860 Visites
can you send the link for the 1.16 update bios?
Message 30 sur 30
7 776 Visites
Message 30 sur 30
7 776 Visites
@kuba
Why don't you check the thread? Read in Post  23
29 RÉPONSES 29
