Akoya P5365 DEAD
26 ANTWOORDEN 26
Tibbles
Bericht 1 van 27
11.343 Weergaven
Bericht 1 van 27
11.343 Weergaven
Akoya P5365 DEAD
My 12 year old PC will not boot up
at least - nothing shows on screen - even the BIOS screen
I replaced the HDD with an SSD and to start with all was fine, but all of a sudden the display went black
Is the Video card dead or is it something else ?
26 ANTWOORDEN 26
Tibbles
Bericht 11 van 27
3.968 Weergaven
Bericht 11 van 27
3.968 Weergaven
Similarly - there is NO eject button for the optical drive
The only way to open the drawer is via Windows !!
No idea why but this PC has always been unique
Tibbles
Bericht 12 van 27
3.960 Weergaven
Bericht 12 van 27
3.960 Weergaven
Bericht 13 van 27
3.954 Weergaven
Bericht 13 van 27
3.954 Weergaven
@Tibbles
To install the new drive you do not have to open the DVD drive!
But I can not believe it. Check this again with a bright lamp. The eject button is very flat and hardly stands out from the panel!
Your picture is not to be seen yet (for o her Users).
Tibbles
Bericht 14 van 27
3.908 Weergaven
Bericht 14 van 27
3.908 Weergaven
Also - is there any BIOS update available ?
At the moment - I cannot tell you the BIOS that is installed - because of a lack of graphics card - but if you could confirm the latest BIOS ... tomorrow, when I receive my Amazon purchased card - if it works ? I can also update the BIOS - it will be the factory supplied version (12 + years old) at present...
Bericht 15 van 27
3.891 Weergaven
Bericht 15 van 27
3.891 Weergaven
Hello @Andi
Can you please correct the data and the image of the mainboard on the Medion service page https://www.medion.com/gb/service/product-detail/10016350 ,
obviously these are not correct because the board MSN 20051613 does not have a VGA and HDMI port.
As it is stored correctly in the internal database / Intranet. see there under 10016350 or 20051613
thanks
Bye Fishtown
Bericht 16 van 27
3.834 Weergaven
Bericht 16 van 27
3.834 Weergaven
@Fishtown
Es  könnte eventuell ein  Irrtum  vorliegen. Auf der Service Page wird für das MSN 10013650 mit dem Board MSN 20051613 ein HDMI und VGA Port angegeben. Auch auf dem  MB ist der Video-Anschlussblock zu sehen.
Es wäre schon merkwürdig wenn in einem Rechner mit integrierter Proc Graphikeinheit  ein MB ohne eigene Videoports verbaut würde. Auch wenn der Rechner mit einer zusätzlichen dedizierten Gafikkarte ausgestattet wird.
Sehe gerade das freigegebene Bild. Da fällt auf daß auf dem Rechner des Users die Videoausschnitte im I/O Shield fehlen
 Vielleicht wurde das eingespart, da der Rechner mit einer dedizierten Grafikkarte vertrieben wurde.
De beiden anderen P5365 mit den MSN 10015454 / MSN 10015805 haben ein andere Version des Mainboards mit der MSN 2004 9146. Das keine HDMI und VGA Anschlüsse in der Auflistung und dem Bild zeigt.
Gruß, daddle
Tibbles
Bericht 17 van 27
3.818 Weergaven
Bericht 17 van 27
3.818 Weergaven
Gibt es ein BIOS-Update? Im Moment kann ich Ihnen nicht sagen, welches BIOS installiert ist - wegen fehlender Grafikkarte - aber ob Sie das neueste BIOS bestätigen könnten
Bericht 18 van 27
3.810 Weergaven
Bericht 18 van 27
3.810 Weergaven
@Tibbles
Warte mal ab ob dein Rechner mit  neuer Grafikkarte überhaupt funktioniert. Und dann lese zuerst die vorhandene Bios Version aus. Ehe wir uns hier auf eine mühselige Suche machen. 😠 😆
Bei dem altem Rechner wird seit langem schon kein neues Bios oder Update mehr erstellt worden sein.
Tibbles
Bericht 19 van 27
3.804 Weergaven
Bericht 19 van 27
3.804 Weergaven
@daddle
OK - Die Ersatzgrafikkarte macht genau das Gleiche wie die alte Karte = überhaupt kein Videoausgang.
Ich habe es an den HDMI-Anschluss des Fernsehers angeschlossen - falls das Problem der Monitor war, obwohl mein Raspberry Pi Video an den Monitor ausgibt.
Ich habe den RAM entfernt und ersetzt, ohne Wirkung.
Der Prozessorlüfter dreht sich wie gewohnt und ich höre die normalen Startgeräusche.
Es kann nichts mit der SSD zu tun haben - denn ich kann nicht einmal das Pre-BIOS sehen.
Was könnte es sonst sein?
Bericht 20 van 27
3.774 Weergaven
Bericht 20 van 27
3.774 Weergaven
@Tibbles
@Tibbles  schrieb:
@daddle
Die Aussage ist falsch. Entweder du siehst wenn im Bíos Quiet boot ausgeschaltet ist, den Post bzw seine Meldungen" .
Ich weiss auch nicht was das Pre-Bios sein soll. Erst kommt der POST, der Check vom Bios, den du aber bei aktiviertem Quiet Boot wie es bei den meisten Rechnern ist nicht siehst.
Er rmüsste wenigstens ohne die neuen Treiber  VGA Auflösung anzeigen. Versuche auch vom MediaCreation Tool  USB Stick (bei ausgebauter Platte) zu booten
Teste besser mit dem Monitor angeschlossen. Beim TV kommt die sichtbare Verbindung oft träge, bzw erst nach Umstellung der Quelle von TV auf HDMI.
Aber nimm mal die SSD bzw die Bootplatte raus, jetzt wo die neue Grafikkarte drin ist. Startet er dann ins Bios?
Die Fehlerursache  kann  vieles sein. Fehler im Proc oder seiner Grafikeinheit. Fehler im Board usw. Das kann man ohne technische Prüfung so aus der Ferne nicht sagen.
Gruß, daddle
26 ANTWOORDEN 26
