MEDION AKOYA P56000 (MD 34030) A-NL upgrade naar W11
15 RÉPONSES 15
noton
Message 1 sur 16
2 415 Visites
Message 1 sur 16
2 415 Visites
Ik wil deze desktop nog upgraden naar W11.
De amd ryzen 5 1600 voldoet niet aan de W11 specs.
Kan ik een andere cpu installeren op dit motherboard, zodat wel aan de specs voldaan wordt?
BVD
2 SOLUTIONS APPROUVÉES
Solutions acceptées
Message 6 sur 16
1 169 Visites
Message 6 sur 16
1 169 Visites
@noton
0. Take the wallsocket plug out
1. Open the case ( left side, two screws at the back)
2. Pull the sidewall backwards
3. Declipse the black air funnell.
4. Open the  fan's power connector plug from the motherboard.
5. Loosen the four screws in the corners of the fan (Sometimes these are spring-loaded retaining pins.)
6. ---> in this case you can press the pins in the corners down and twist them (approx. 60°) to secure them in the relaxed position.
7. Remove the fan and heatsink (the fan often has a few hooks clipped onto the heatsink).
8. After that, you can remove the processor and clean the old thermal paste from the heatsink with a tissue and some alcohol solution.
Pay attention to the marked corner (usually indicated by the beveled pin arrangement), which you will also find on the new processor.
9. Apply new thermal paste to the raised part of the processor where the heatsink rests. It's best to apply it to the contact surface to a thickness of about 1/2 mm.
10. After inserting the processor, place the heatsink with the clipped-on fan in the center and tighten the retaining screws. The spring-loaded retaining pins can be re-fixed by turning them backwards.
11. Replug the fans power cord into the mainboard socket
12. Reclipse the air  funnel back
Groetjes, daddle
Message 13 sur 16
1 400 Visites
Message 13 sur 16
1 400 Visites
@noton
Ja dit is merkwaardig. Maar definitief (actueel gisteren nog nagekeken) in de P56005 moederboord (ECS B550A4-EM), zegt de PC in instellingen ->  Update  hij  is goedgekeurd voor upgrade naar Win 11. Dus daarmee ook de Proc AMD Ryzen 5 1600
groet, daddle
15 RÉPONSES 15
Message 2 sur 16
1 778 Visites
Message 2 sur 16
1 778 Visites
Hi @noton
zieh hier:
https://community.medion.com/t5/kb/en/ta-p/138828
doei Fishtown
noton
Message 3 sur 16
1 775 Visites
Message 3 sur 16
1 775 Visites
Oke  dank U.
Dus een Ryzer 5 of zelfs een 7 zou zonder aanpassingen geplaats kunnen worden?
Welke processor zou U aanbevelen?
Ik hoef niet veel meer snelheid. De computer voldoet nu goed.
Ik wil er ook niet meer al te veel geld aan uitgeven.
BVD
Mastermind
Message 4 sur 16
1 188 Visites
Message 4 sur 16
1 188 Visites
Hi @noton ,
heb je je beslissing al genomen? We hebben vergelijkbare pc's verkocht, inclusief die CPU's.
RYZEN7-1700 3.0GHZ 65W
RYZEN5-1600 3.2GHZ 65W
Uiteraard moet u ervoor zorgen dat de nieuwste BIOS-versie al is geïnstalleerd voordat u de nieuwe CPU toevoegt.
Groetjes
noton
Message 5 sur 16
1 178 Visites
Message 5 sur 16
1 178 Visites
Thanks. Major Tom
I will go for the RYZEN5-1600 3.2GHZ 65W.
Is there a "how to do it" article?
This will be my first processor swap.
Or is it hop off and hop on???
Message 6 sur 16
1 170 Visites
Message 6 sur 16
1 170 Visites
@noton
Groetjes, daddle
noton
Message 7 sur 16
1 164 Visites
Message 7 sur 16
1 164 Visites
Thanks Daddle for the information.
This is a very clear story.
Thanks again.
Message 8 sur 16
1 066 Visites
Message 8 sur 16
1 066 Visites
@noton
@noton  schrieb:
Thanks. Major Tom
Why do you go for the  RYZEN5-1600 3.2GHZ? That is your original Proc built in to the retail version of your PC  P56000, like you wrote in Post1.
You said it isn't Win 11 compatible.
noton
Message 9 sur 16
1 036 Visites
Message 9 sur 16
1 036 Visites
Oh, now I see. You are right.
I will go for the RYZEN7-1700 3.0GHZ 65W
Thanks
Message 10 sur 16
800 Visites
Message 10 sur 16
800 Visites
@Major_ToM
Hallo Major,
kannst du mir auch eine Empfehlung geben bzw. sagen welche AMD Procs ihr im MB 20066891 (u.a. im P56005 oder anderen PCs) verbaut habt, oder generell welche schnelleren  AMD Procs passen würden. Ursprünglich verbaut war ein AMD AM4 RYZEN5-2600 3.4GHZ 65W.
Muss den Proc wegen dem Upgrade auf Win 11 im Rechner meiner Frau austauschen, und würde ihn gleichzeitig gerne etwas beschleunigen.
Dieses MB hat auch den AM4 CPU Sockel, aber einen höheren Chipsatz AMD B550 und eine TDP von max 95 W.
Vielen Dank Gruß, daddle
15 RÉPONSES 15
