MEDION AKOYA P56000 (MD 34030) A-NL upgrade naar W11
15 ANTWOORDEN 15
noton
Bericht 1 van 16
2.960 Weergaven
Bericht 1 van 16
2.960 Weergaven
Ik wil deze desktop nog upgraden naar W11.
De amd ryzen 5 1600 voldoet niet aan de W11 specs.
Kan ik een andere cpu installeren op dit motherboard, zodat wel aan de specs voldaan wordt?
BVD
2 GEACCEPTEERDE OPLOSSINGEN
Geaccepteerd Solutions
Bericht 6 van 16
1.533 Weergaven
Bericht 6 van 16
1.533 Weergaven
@noton
0. Take the wallsocket plug out
1. Open the case ( left side, two screws at the back)
2. Pull the sidewall backwards
3. Declipse the black air funnell.
4. Open the  fan's power connector plug from the motherboard.
5. Loosen the four screws in the corners of the fan (Sometimes these are spring-loaded retaining pins.)
6. ---> in this case you can press the pins in the corners down and twist them (approx. 60°) to secure them in the relaxed position.
7. Remove the fan and heatsink (the fan often has a few hooks clipped onto the heatsink).
8. After that, you can remove the processor and clean the old thermal paste from the heatsink with a tissue and some alcohol solution.
Pay attention to the marked corner (usually indicated by the beveled pin arrangement), which you will also find on the new processor.
9. Apply new thermal paste to the raised part of the processor where the heatsink rests. It's best to apply it to the contact surface to a thickness of about 1/2 mm.
10. After inserting the processor, place the heatsink with the clipped-on fan in the center and tighten the retaining screws. The spring-loaded retaining pins can be re-fixed by turning them backwards.
11. Replug the fans power cord into the mainboard socket
12. Reclipse the air  funnel back
Groetjes, daddle
Bericht 13 van 16
1.945 Weergaven
Bericht 13 van 16
1.945 Weergaven
@noton
Ja dit is merkwaardig. Maar definitief (actueel gisteren nog nagekeken) in de P56005 moederboord (ECS B550A4-EM), zegt de PC in instellingen ->  Update  hij  is goedgekeurd voor upgrade naar Win 11. Dus daarmee ook de Proc AMD Ryzen 5 1600
groet, daddle
15 ANTWOORDEN 15
Bericht 2 van 16
2.142 Weergaven
Bericht 2 van 16
2.142 Weergaven
Hi @noton
zieh hier:
https://community.medion.com/t5/kb/en/ta-p/138828
doei Fishtown
noton
Bericht 3 van 16
2.139 Weergaven
Bericht 3 van 16
2.139 Weergaven
Oke  dank U.
Dus een Ryzer 5 of zelfs een 7 zou zonder aanpassingen geplaats kunnen worden?
Welke processor zou U aanbevelen?
Ik hoef niet veel meer snelheid. De computer voldoet nu goed.
Ik wil er ook niet meer al te veel geld aan uitgeven.
BVD
Mastermind
Bericht 4 van 16
1.552 Weergaven
Bericht 4 van 16
1.552 Weergaven
Hi @noton ,
heb je je beslissing al genomen? We hebben vergelijkbare pc's verkocht, inclusief die CPU's.
RYZEN7-1700 3.0GHZ 65W
RYZEN5-1600 3.2GHZ 65W
Uiteraard moet u ervoor zorgen dat de nieuwste BIOS-versie al is geïnstalleerd voordat u de nieuwe CPU toevoegt.
Groetjes
noton
Bericht 5 van 16
1.542 Weergaven
Bericht 5 van 16
1.542 Weergaven
Thanks. Major Tom
I will go for the RYZEN5-1600 3.2GHZ 65W.
Is there a "how to do it" article?
This will be my first processor swap.
Or is it hop off and hop on???
Bericht 6 van 16
1.534 Weergaven
Bericht 6 van 16
1.534 Weergaven
@noton
Groetjes, daddle
noton
Bericht 7 van 16
1.528 Weergaven
Bericht 7 van 16
1.528 Weergaven
Thanks Daddle for the information.
This is a very clear story.
Thanks again.
Bericht 8 van 16
1.430 Weergaven
Bericht 8 van 16
1.430 Weergaven
@noton
@noton  schrieb:
Thanks. Major Tom
Why do you go for the  RYZEN5-1600 3.2GHZ? That is your original Proc built in to the retail version of your PC  P56000, like you wrote in Post1.
You said it isn't Win 11 compatible.
noton
Bericht 9 van 16
1.400 Weergaven
Bericht 9 van 16
1.400 Weergaven
Oh, now I see. You are right.
I will go for the RYZEN7-1700 3.0GHZ 65W
Thanks
Bericht 10 van 16
1.164 Weergaven
Bericht 10 van 16
1.164 Weergaven
@Major_ToM
Hallo Major,
kannst du mir auch eine Empfehlung geben bzw. sagen welche AMD Procs ihr im MB 20066891 (u.a. im P56005 oder anderen PCs) verbaut habt, oder generell welche schnelleren  AMD Procs passen würden. Ursprünglich verbaut war ein AMD AM4 RYZEN5-2600 3.4GHZ 65W.
Muss den Proc wegen dem Upgrade auf Win 11 im Rechner meiner Frau austauschen, und würde ihn gleichzeitig gerne etwas beschleunigen.
Dieses MB hat auch den AM4 CPU Sockel, aber einen höheren Chipsatz AMD B550 und eine TDP von max 95 W.
Vielen Dank Gruß, daddle
15 ANTWOORDEN 15
