le 06.06.2025 20:57
le 06.06.2025 20:57
Ik wil deze desktop nog upgraden naar W11.
De amd ryzen 5 1600 voldoet niet aan de W11 specs.
Kan ik een andere cpu installeren op dit motherboard, zodat wel aan de specs voldaan wordt?
BVD
15.10.2025 15:52 - modifié 15.10.2025 15:59
0. Take the wallsocket plug out
1. Open the case ( left side, two screws at the back)
2. Pull the sidewall backwards
3. Declipse the black air funnell.
4. Open the fan's power connector plug from the motherboard.
5. Loosen the four screws in the corners of the fan (Sometimes these are spring-loaded retaining pins.)
6. ---> in this case you can press the pins in the corners down and twist them (approx. 60°) to secure them in the relaxed position.
7. Remove the fan and heatsink (the fan often has a few hooks clipped onto the heatsink).
8. After that, you can remove the processor and clean the old thermal paste from the heatsink with a tissue and some alcohol solution.
Pay attention to the marked corner (usually indicated by the beveled pin arrangement), which you will also find on the new processor.
9. Apply new thermal paste to the raised part of the processor where the heatsink rests. It's best to apply it to the contact surface to a thickness of about 1/2 mm.
10. After inserting the processor, place the heatsink with the clipped-on fan in the center and tighten the retaining screws. The spring-loaded retaining pins can be re-fixed by turning them backwards.
11. Replug the fans power cord into the mainboard socket
12. Reclipse the air funnel back
Groetjes, daddle
24.10.2025 10:23 - modifié 24.10.2025 10:57
Ja dit is merkwaardig. Maar definitief (actueel gisteren nog nagekeken) in de P56005 moederboord (ECS B550A4-EM), zegt de PC in instellingen -> Update hij is goedgekeurd voor upgrade naar Win 11. Dus daarmee ook de Proc AMD Ryzen 5 1600
groet, daddle
le 06.06.2025 21:17
le 06.06.2025 21:17
Hi @noton
zieh hier:
https://community.medion.com/t5/kb/en/ta-p/138828
doei Fishtown
le 06.06.2025 21:32
le 06.06.2025 21:32
Oke dank U.
Dus een Ryzer 5 of zelfs een 7 zou zonder aanpassingen geplaats kunnen worden?
Welke processor zou U aanbevelen?
Ik hoef niet veel meer snelheid. De computer voldoet nu goed.
Ik wil er ook niet meer al te veel geld aan uitgeven.
BVD
le 15.10.2025 09:14
le 15.10.2025 09:14
Hi @noton ,
heb je je beslissing al genomen? We hebben vergelijkbare pc's verkocht, inclusief die CPU's.
RYZEN7-1700 3.0GHZ 65W
RYZEN5-1600 3.2GHZ 65W
Uiteraard moet u ervoor zorgen dat de nieuwste BIOS-versie al is geïnstalleerd voordat u de nieuwe CPU toevoegt.
Groetjes
le 15.10.2025 12:49
le 15.10.2025 12:49
Thanks. Major Tom
I will go for the RYZEN5-1600 3.2GHZ 65W.
Is there a "how to do it" article?
This will be my first processor swap.
Or is it hop off and hop on???
Groetjes, daddle
le 15.10.2025 18:02
le 15.10.2025 18:02
Thanks Daddle for the information.
This is a very clear story.
Thanks again.
le 19.10.2025 17:35
le 19.10.2025 20:43
le 19.10.2025 20:43
Oh, now I see. You are right.
I will go for the RYZEN7-1700 3.0GHZ 65W
Thanks
23.10.2025 20:14 - modifié 23.10.2025 20:29
Hallo Major,
kannst du mir auch eine Empfehlung geben bzw. sagen welche AMD Procs ihr im MB 20066891 (u.a. im P56005 oder anderen PCs) verbaut habt, oder generell welche schnelleren AMD Procs passen würden. Ursprünglich verbaut war ein AMD AM4 RYZEN5-2600 3.4GHZ 65W.
Muss den Proc wegen dem Upgrade auf Win 11 im Rechner meiner Frau austauschen, und würde ihn gleichzeitig gerne etwas beschleunigen.
Dieses MB hat auch den AM4 CPU Sockel, aber einen höheren Chipsatz AMD B550 und eine TDP von max 95 W.
Vielen Dank Gruß, daddle
